I am trying to set an IP on one of my interfaces and it will not save. Within the GUI I go to the interface and disable DHCP and Autoconfigure IPv6 and it allows me to enter in an Alias. I enter in 10.0.1.2/24 and hit save and nothing changes. A small progress bar at the top of the small config window flicks by and the save button grays out and nothing changes. I can still set the other interfaces through the GUI just fine. I have tried using netcli to reset the interface, using the garbage can next to the interface, and rebooting the whole server in between tries.
The only way I have been able to get an ip set on this interface was ifconfig and manually entering it in but the IP only seems to stick for a few seconds and then is gone again and changing it again only intermittently works.
Can anyone think of why this one interface is broken or how to reset it at a deeper level?
I'm on an HPE Apollo 4200 G9 running 22.12.0 Bluefin.
