cannot boot from usb stick, bios should be fine
Artexanis
This is the problem where it all started: http://forums.freenas.org/showthread.php?8028-recovering-data-from-broken-freenas-8
So, now i got my data back i needed to reïnstall. The usb stick was booting fine before the reïnstallation, so the BIOS settings should be ok.
Ik reïnstalled using this howto: http://anichin.com/blog/2012/05/installing-freenas-to-usb-stick-simpler-way/
When I try to start from de USB stick the last thing that appears on screen (and won't go away):
Verifying DMI pool data .... update success
_
I'm stuck at this point... any help?
Thanks!
Artexanis
It seems like the boot sector of the usb stick is corrupted, how is this possible? I just wrote the image downloaded from FreeNAS, can it be corrupt? I tried 3 times.
I will now try to download an old version.
paleoN
Throw out the USB stick and try a new one?
Artexanis
I used the same usb stick from the previous installation, it booted without any problem... I will try another stick, but I doubt that there will be any diffrence. I'll post back.
Artexanis
Forgot to post the result, after trying a new usb-stick the problem was solved. Strange, the same usb-stick had no problem at all booting the previous installation...
