In my opinion it should be enabled because I had the possibility to update my BIOS from internet, It worked.Is the NIC enabled in your BIOS?
Do you have a link light on the NIC?
man less
will teach you how to use it. In a nutshell, SPACE goes forward, b goes back, q quits, and / searches.many thanks for your instructions!Well the i219V is there. In your dmesg, I don't see the relevant portion about Intel, did you actually scroll to the part where the Intel Ethernet driver tries to load?man less
“No driver attached” in dmesg for 31.6 which is your Intel NIC. Highly unfortunate.
Fiddling with addon drivers is tricky. Doable but tricky. I’ll suggest to side-step the issue by buying an i210 Intel NIC on eBay, they are around 20 bucks, or maybe one of the server intel nics on eBay, around the same cost. You can use that to get up and running and then take your time to find out what’s going on with the FreeBSD drivers for i219v.
