seohyunxian
- Jan 24, 2017
freenas.HOME changes in mounted filesystems:
0a1,2
> /mnt/mynas/Video /mnt/mynas/jails/plex_server/media nullfs rw 0 0
> /mnt/mynas/owncloud_files /mnt/mynas/jails/owncloud/usr/local/www/owncloud/data nullfs rw 0 0
1a4,6
> devfs /mnt/mynas/jails/owncloud/dev devfs rw,multilabel 0 0
> devfs /mnt/mynas/jails/phpMyAdmin/dev devfs rw,multilabel 0 0
> devfs /mnt/mynas/jails/plex_server/dev devfs rw,multilabel 0 0
3c8
< freenas-boot/ROOT/default / zfs rw,noatime,nfsv4acls 0 0
> freenas-boot/ROOT/9.10.2-U1 / zfs rw,noatime,nfsv4acls 0 0
12d16
< mynas/Owncloud /mnt/mynas/Owncloud zfs rw,nfsv4acls 0 0
14a19,23
> mynas/jails/.warden-template-standard-10.3 /mnt/mynas/jails/.warden-template-standard-10.3 zfs rw,nfsv4acls 0 0
> mynas/jails/owncloud /mnt/mynas/jails/owncloud zfs rw,nfsv4acls 0 0
> mynas/jails/phpMyAdmin /mnt/mynas/jails/phpMyAdmin zfs rw,nfsv4acls 0 0
> mynas/jails/plex_server /mnt/mynas/jails/plex_server zfs rw,nfsv4acls 0 0
> mynas/owncloud_files /mnt/mynas/owncloud_files zfs rw,nfsv4acls 0 0
19a29,31
> procfs /mnt/mynas/jails/owncloud/proc procfs rw 0 0
> procfs /mnt/mynas/jails/phpMyAdmin/proc procfs rw 0 0
> procfs /mnt/mynas/jails/plex_server/proc procfs rw 0 0
freenas.HOME kernel log messages:
> FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017
> VT(efifb): resolution 1280x1024
> real memory = 4821352448 (4598 MB)
> avail memory = 4025360384 (3838 MB)
> module_register_init: MOD_LOAD (vesa, 0xffffffff80e48970, 0) error 19
> vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0xe0000000-0xefffffff at device 2.0 on pci0
> ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7d08000-0xf7d083ff at device 26.0 on pci0
> pci0: <multimedia, HDA> at device 27.0 (no driver attached)
> pcib1: <ACPI PCI-PCI bridge> at device 28.0 on pci0
> pcib2: <ACPI PCI-PCI bridge> at device 28.2 on pci0
> pcib4: <ACPI PCI-PCI bridge> at device 28.4 on pci0
> re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xf7c04000-0xf7c04fff,0xf7c00000-0xf7c03fff at device 0.0 on pci4
> ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7d07000-0xf7d073ff at device 29.0 on pci0
> ahci0: <Intel Cougar Point AHCI SATA controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf060-0xf07f mem 0xf7d06000-0xf7d067ff at device 31.2 on pci0
> ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
> to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
> uhub0: 2 ports with 2 removable, self powered
> Timecounter "TSC-low" frequency 1696185694 Hz quality 1000
> Trying to mount root from zfs:freenas-boot/ROOT/9.10.2-U1 []...
> bridge0: Ethernet address: 02:7d:d4:30:b1:00
> re0: promiscuous mode enabled
> bridge0: link state changed to UP
> epair0a: Ethernet address: 02:ff:20:00:04:0a
> epair0b: Ethernet address: 02:ff:70:00:05:0b
> epair0a: link state changed to UP
> epair0b: link state changed to UP
> re0: link state changed to DOWN
> epair0a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair0b
> re0: link state changed to UP
> epair1a: Ethernet address: 02:ff:20:00:05:0a
> epair1b: Ethernet address: 02:ff:70:00:06:0b
> epair1a: link state changed to UP
> epair1b: link state changed to UP
> epair1a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair1b
> epair2a: Ethernet address: 02:ff:20:00:06:0a
> epair2b: Ethernet address: 02:ff:70:00:07:0b
> epair2a: link state changed to UP
> epair2b: link state changed to UP
> epair2a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair2b
> pid 7319 (Plex DLNA Server), uid 972: exited on signal 11
> epair1a: link state changed to DOWN
> epair1b: link state changed to DOWN
> epair1b: Ethernet address: 02:ff:70:00:07:0b
> ifa_del_loopback_route: deletion failed: 48
> Freed UMA keg (udp_inpcb) was not empty (90 items). Lost 9 pages of memory.
> Freed UMA keg (udpcb) was not empty (835 items). Lost 5 pages of memory.
> Freed UMA keg (tcptw) was not empty (540 items). Lost 12 pages of memory.
> Freed UMA keg (tcp_inpcb) was not empty (119 items). Lost 12 pages of memory.
> Freed UMA keg (sackhole) was not empty (625 items). Lost 5 pages of memory.
> Freed UMA keg (tcpcb) was not empty (44 items). Lost 15 pages of memory.
> hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required
> hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
> Fatal trap 12: page fault while in kernel mode
> cpuid = 0; apic id = 00
> fault virtual address = 0x378
> fault code = supervisor read data, page not present
> instruction pointer = 0x20:0xffffffff8095ddf9
> stack pointer = 0x28:0xfffffe00f2f83810
> frame pointer = 0x28:0xfffffe00f2f838b0
> code segment = base 0x0, limit 0xfffff, type 0x1b
> = DPL 0, pres 1, long 1, def32 0, gran 1
> processor eflags = interrupt enabled, resume, IOPL = 0
> current process = 12 (swi4: clock)
> SMP: AP CPU #2 Launched!
> Timecounter "TSC-low" frequency 1696183428 Hz quality 1000
> GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
> hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI>
> uhid0: <SIGMACHIP USB keyboard, class 0/0, rev 1.10/1.40, addr 3> on usbus1
> GEOM_ELI: Device ada2p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 128
> GEOM_ELI: Crypto: software
> GEOM_ELI: Device ada0p1.eli created.
> GEOM_ELI: Device ada1p1.eli created.
> pid 7392 (Plex DLNA Server), uid 972: exited on signal 11
> pid 1340 (syslog-ng), uid 0: exited on signal 6 (core dumped)
> epair0a: link state changed to DOWN
> epair0b: link state changed to DOWN
> Freed UMA keg (udp_inpcb) was not empty (120 items). Lost 12 pages of memory.
> Freed UMA keg (udpcb) was not empty (1169 items). Lost 7 pages of memory.
> Freed UMA keg (tcptw) was not empty (270 items). Lost 6 pages of memory.
> Freed UMA keg (tcp_inpcb) was not empty (120 items). Lost 12 pages of memory.
> Freed UMA keg (tcpcb) was not empty (54 items). Lost 18 pages of memory.
> epair2a: link state changed to DOWN
> epair2b: link state changed to DOWN
> bridge0: link state changed to DOWN
> re0: promiscuous mode disabled
> Freed UMA keg (tcp_inpcb) was not empty (149 items). Lost 15 pages of memory.
> Freed UMA keg (tcpcb) was not empty (53 items). Lost 18 pages of memory.
> Copyright (c) 1992-2016 The FreeBSD Project.
> Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
> The Regents of the University of California. All rights reserved.
> FreeBSD is a registered trademark of The FreeBSD Foundation.
> root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64
> FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
> CPU: Intel(R) Core(TM) i3-3240 CPU @ 3.40GHz (3392.37-MHz K8-class CPU)
> Origin="GenuineIntel" Id=0x306a9 Family=0x6 Model=0x3a Stepping=9
> Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
> Features2=0x3d9ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE,OSXSAVE,AVX,F16C>
> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
> AMD Features2=0x1<LAHF>
> Structured Extended Features=0x281<FSGSBASE,SMEP,ERMS>
> XSAVE Features=0x1<XSAVEOPT>
> VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID
> TSC: P-state invariant, performance statistics
> Event timer "LAPIC" quality 600
> ACPI APIC Table: <LENOVO TC-F9 >
> FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
> FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
> cpu0 (BSP): APIC ID: 0
> cpu1 (AP): APIC ID: 1
> cpu2 (AP): APIC ID: 2
> cpu3 (AP): APIC ID: 3
> random: <Software, Yarrow> initialized
> WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
> ioapic0 <Version 2.0> irqs 0-23 on motherboard
> kbd1 at kbdmux0
> aesni0: No AESNI support.
> padlock0: No ACE support.
> cryptosoft0: <software crypto> on motherboard
> acpi0: <LENOVO TC-F9> on motherboard
> acpi0: Power Button (fixed)
> cpu0: <ACPI CPU> on acpi0
> cpu1: <ACPI CPU> on acpi0
> cpu2: <ACPI CPU> on acpi0
> cpu3: <ACPI CPU> on acpi0
> hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
> Timecounter "HPET" frequency 14318180 Hz quality 950
> Event timer "HPET" frequency 14318180 Hz quality 550
> Event timer "HPET1" frequency 14318180 Hz quality 440
> Event timer "HPET2" frequency 14318180 Hz quality 440
> Event timer "HPET3" frequency 14318180 Hz quality 440
> Event timer "HPET4" frequency 14318180 Hz quality 440
> atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
> atrtc0: Warning: Couldn't map I/O.
> Event timer "RTC" frequency 32768 Hz quality 0
> attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
> Timecounter "i8254" frequency 1193182 Hz quality 0
> Event timer "i8254" frequency 1193182 Hz quality 100
> Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
> acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
> pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
> pci0: <ACPI PCI bus> on pcib0
> agp0: <IvyBridge desktop GT1 IG> on vgapci0
> agp0: aperture size is 256M, detected 32764k stolen memory
> vgapci0: Boot video device
> pci0: <simple comms> at device 22.0 (no driver attached)
> usbus0: EHCI version 1.0
> usbus0 on ehci0
> pci1: <ACPI PCI bus> on pcib1
> pci2: <ACPI PCI bus> on pcib2
> pcib3: <ACPI PCI-PCI bridge> at device 0.0 on pci2
> pci3: <ACPI PCI bus> on pcib3
> pci4: <ACPI PCI bus> on pcib4
> re0: Using 1 MSI-X message
> re0: Chip rev. 0x48000000
> re0: MAC rev. 0x00000000
> miibus0: <MII bus> on re0
> rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
> rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
> re0: Using defaults for TSO: 65518/35/2048
> re0: Ethernet address: c0:3f:d5:9c:f1:d7
> usbus1: EHCI version 1.0
> usbus1 on ehci1
> isab0: <PCI-ISA bridge> at device 31.0 on pci0
> isa0: <ISA bus> on isab0
> ahci0: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
> ahcich0: <AHCI channel> at channel 0 on ahci0
> ahcich1: <AHCI channel> at channel 1 on ahci0
> ahcich5: <AHCI channel> at channel 5 on ahci0
> acpi_button0: <Power Button> on acpi0
> acpi_tz0: <Thermal Zone> on acpi0
> acpi_tz1: <Thermal Zone> on acpi0
> uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
> uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
> ichwd0: <Intel Cougar Point watchdog timer> on isa0
> atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
> atkbd0: <AT Keyboard> irq 1 on atkbdc0
> kbd0 at atkbd0
> atkbd0: [GIANT-LOCKED]
> coretemp0: <CPU On-Die Thermal Sensors> on cpu0
> est0: <Enhanced SpeedStep Frequency Control> on cpu0
> coretemp1: <CPU On-Die Thermal Sensors> on cpu1
> est1: <Enhanced SpeedStep Frequency Control> on cpu1
> coretemp2: <CPU On-Die Thermal Sensors> on cpu2
> est2: <Enhanced SpeedStep Frequency Control> on cpu2
> coretemp3: <CPU On-Die Thermal Sensors> on cpu3
> est3: <Enhanced SpeedStep Frequency Control> on cpu3
> random: unblocking device.
> usbus0: 480Mbps High Speed USB v2.0
> usbus1: 480Mbps High Speed USB v2.0
> ZFS filesystem version: 5
> ZFS storage pool version: features support (5000)
> Timecounters tick every 1.000 msec
> ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
> ugen1.1: <Intel> at usbus1
> uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
> ugen0.1: <Intel> at usbus0
> uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
> uhub1: 2 ports with 2 removable, self powered
> ugen0.2: <vendor 0x8087> at usbus0
> uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
> ugen1.2: <vendor 0x8087> at usbus1
> uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
> uhub2: 4 ports with 4 removable, self powered
> uhub3: 6 ports with 6 removable, self powered
> ugen1.3: <SIGMACHIP> at usbus1
> ukbd0: <SIGMACHIP USB keyboard, class 0/0, rev 1.10/1.40, addr 3> on usbus1
> kbd2 at ukbd0
> ugen1.4: <SanDisk> at usbus1
> umass0: <SanDisk Cruzer Force, class 0/0, rev 2.00/1.27, addr 4> on usbus1
> umass0: SCSI over Bulk-Only; quirks = 0x8100
> umass0:4:0:-1: Attached to scbus4
> ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
> ada0: <ST1000DM010-2EP102 CC43> ATA8-ACS SATA 3.x device
> ada0: Serial Number W9A3TDZV
> ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
> ada0: Command Queueing enabled
> ada0: 953869MB (1953525168 512 byte sectors)
> ada0: quirks=0x1<4K>
> ada0: Previously was known as ad4
> ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
> ada1: <ST1000DM010-2EP102 CC43> ATA8-ACS SATA 3.x device
> ada1: Serial Number W9A55E70
> ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
> ada1: Command Queueing enabled
> ada1: 953869MB (1953525168 512 byte sectors)
> ada1: quirks=0x1<4K>
> ada1: Previously was known as ad6
> ada2 at ahcich5 bus 0 scbus2 target 0 lun 0
> ada2: <ST1000DM010-2EP102 CC43> ATA8-ACS SATA 3.x device
> ada2: Serial Number W9A56AG3
> ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
> ada2: Command Queueing enabled
> ada2: 953869MB (1953525168 512 byte sectors)
> ada2: quirks=0x1<4K>
> ada2: Previously was known as ad8
> da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
> da0: <SanDisk Cruzer Force 1.27> Removable Direct Access SPC-4 SCSI device
> da0: Serial Number 4C530013210615123154
> da0: 40.000MB/s transfers
> da0: 15267MB (31266816 512 byte sectors)
> da0: quirks=0x2<NO_6_BYTE>
> SMP: AP CPU #1 Launched!
> SMP: AP CPU #3 Launched!
> Timecounter "TSC-low" frequency 1696187286 Hz quality 1000
> pid 9980 (Plex Media Scanner), uid 972: exited on signal 11
> pid 9981 (Plex Media Scanner), uid 972: exited on signal 11
> pid 9983 (Plex Media Scanner), uid 972: exited on signal 11
> pid 9991 (Plex Media Scanner), uid 972: exited on signal 11
> pid 9993 (Plex Media Scanner), uid 972: exited on signal 11
> pid 9994 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10012 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10015 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10017 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10020 (Plex Media Scanner), uid 972: exited on signal 10
> pid 10023 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10024 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10027 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10029 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10030 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10050 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10052 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10054 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10055 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10058 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10060 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10061 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10064 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10066 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10069 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10070 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10072 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10073 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10088 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10209 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10211 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10212 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10214 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10216 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10219 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10220 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10222 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10224 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10225 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10243 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10244 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10247 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10250 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10251 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10253 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10254 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10256 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10259 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10261 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10280 (Plex Media Scanner), uid 972: exited on signal 6
> pid 10283 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10285 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10286 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10288 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10290 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10292 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10305 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10308 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10310 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10311 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10313 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10314 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10316 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10318 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10320 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10347 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10348 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10350 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10352 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10355 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10367 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10369 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10371 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10389 (Plex Media Scanner), uid 972: exited on signal 6
> pid 10391 (Plex Media Scanner), uid 972: exited on signal 10
> pid 10394 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10396 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10397 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10399 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10402 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10403 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10405 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10407 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10408 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10410 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10432 (Plex Media Scanner), uid 972: exited on signal 10
> pid 10435 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10437 (Plex Media Scanner), uid 972: exited on signal 10
> pid 10439 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10441 (Plex Media Scanner), uid 972: exited on signal 11
> pid 10442 (Plex Media Scanner), uid 972: exited on signal 11
-- End of security output --
0a1,2
1a4,6
3c8
12d16
14a19,23
19a29,31
> kbd1 at kbdmux0
> usbus0 on ehci0
> usbus1 on ehci1
> kbd0 at atkbd0
> kbd2 at ukbd0
