Can writing continue after RAIDZ1 is downgraded?
dktech
My RAIDZ1 has a broken HDD, and the verification is being restored after the replacement. Can I continue to use it at this time? Will the written data be corrupted (I use Google Translate), thanks for the reply!
No sane filesystem would allow this and ZFS is sane, so no, it will not.
Yes, but you will naturally slow things down by adding workload to the pool.
dktech
谢谢回答,你的意思是我可以写数据,但同时会影响RAIDZ的奇偶校验速度,写的数据不会有错误?
没有健全的文件系统会允许这样做,而 ZFS 是健全的,所以不,它不会。
是的,但是您自然会通过向池中添加工作负载来减慢速度。
HoneyBadger
actually does care
Administrator
Thank you for answering, you mean I can write data, but at the same time it will affect the parity speed of RAIDZ, and the data written will not have errors?
All parts of your statement are correct.
Because of the rebuild, your pool is experiencing an increased load. New writes will have to compete with this traffic, which will slow down pool performance.
Any new data will not have errors at the time it is written; however, until your resilver or "repair" operation is complete, you are still vulnerable to corruption in existing files.
Please excuse any errors in translation.
你陈述的所有部分都是正确的。
由于重建,您的池正在经历增加的负载。 新写入将不得不与此流量竞争,这将降低池性能。
任何新数据在写入时都不会出错; 但是,在您的重新同步或“修复”操作完成之前,您仍然容易受到现有文件损坏的影响。
请原谅翻译中的任何错误。
dktech
你陈述的所有部分都是正确的。
请原谅翻译中的任何错误。
非常感谢您的回复,谢谢
