Two weeks ago, on my FreeNAS unit one of my disks failed, so I sent it to HGST for a warranty replacement. After I received the replacement disk (same type, same size), I installed it, but could not replace the degraded ZFS pool. It seems like the new disk is not fully recognized by my system and I am clueless. The device cannot query its size, I can not write anything to it. I also tried different slots in the chassis, same results.
Does anyone here have an idea? Is there some special BSD magic that I overlooked? Or is it possible they sent me a faulty device? Unfortunately, this is the only machine I have available, that has SAS ports.
System info:
I set the defect disk to offline and tried to
Even
This is in
I tried to
Replacing the disk with the web interface fails with:
System info:
Mainboard: Supermicro X11SSL-CF SAS Controller: LSI SAS3008 (Onboard) Chassis: Supermicro SuperChassis 836BE1C-R1K03B SAS Backplane: Supermicro HD Backplane BPN-SAS3-836EL2 CPU: Intel(R) Xeon(R) CPU E3-1240 v5 @ 3.50GHz RAM: 32 GB ECC Boot device: Samsung SSD 850 EVO 250GB ZFS Pool (RAIDZ2): 4 x SEAGATE ST10000NM0206 10TB 4 x HGST HUH721010AL5200 10TB (One of these failed)
zpool status:Code:
root@discworld ~ # zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:36 with 0 errors on Sat Aug 22 03:45:36 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
pool: pool
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0 in 0 days 20:25:18 with 0 errors on Mon Jul 20 20:25:19 2020
pool DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/efc6973c-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
gptid/f0f67dd6-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
gptid/f21563c2-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
gptid/f336aa8a-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
gptid/f450bd90-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
gptid/f563cdb8-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
426474221169454384 OFFLINE 0 0 0 was /dev/gptid/f678f62b-f415-11e8-a34d-0cc47a85297e
gptid/f78ff78b-f415-11e8-a34d-0cc47a85297e ONLINE 0 0 0
zpool replace it:Code:
root@discworld ~ # zpool replace pool 426474221169454384 /dev/da6 cannot replace 426474221169454384 with /dev/da6: device is too small
Even
smartctl is not successful:Code:
smartctl -i /dev/da6 smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: HGST Product: HUH721010AL5200 Revision: A21D Compliance: SPC-4 LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000cca251100588 Serial number: 7PG8U4PS Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Thu Aug 27 19:57:17 2020 CEST device is NOT READY (e.g. spun down, busy) A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
This is in
/var/log/messages:Code:
root@discworld ~ # grep da6 /var/log/messages | grep '10:2' Aug 27 10:28:01 discworld da6 at mpr0 bus 0 scbus0 target 14 lun 0 Aug 27 10:28:01 discworld da6: <HGST HUH721010AL5200 A21D> Fixed Direct Access SPC-4 SCSI device Aug 27 10:28:01 discworld da6: Serial Number 7PG8U4PS Aug 27 10:28:01 discworld da6: 1200.000MB/s transfers Aug 27 10:28:01 discworld da6: Command Queueing enabled Aug 27 10:28:01 discworld da6: Attempt to query device size failed: NOT READY, Logical unit not ready, initial Aug 27 10:28:01 discworld ses0: da6,pass6 in 'Slot06', SAS Slot: 1 phys at slot 6
I tried to
dd to the disk, but nothing can be written:Code:
root@discworld ~ # dd if=/dev/zero of=/dev/da6 count=100 dd: /dev/da6: Device not configured 1+0 records in 0+0 records out 0 bytes transferred in 0.000036 secs (0 bytes/sec)
Replacing Disk Error: [EFAULT] Failed to wipe disk da6: [EFAULT] Command gpart create -s gpt /dev/da6 failed (code 1): gpart: provider: Operation not supported by device
