Calibre in the plugin jail
fontes31
adrianwi
I don't know as I'm still not sure where you're mounting the jail storage.
Why not just mount your calibre library location (guessing this is /mnt/tank/media/calibreLibrary ?) to /mnt in your jail?
The library="/mnt" should work fine, so when you run the Cron task you should be able to access calibre from the jail IP on port 8282 e.g. http://jail.ip:8282
fontes31
yes, my calibre location is /mnt/tank/media/calibreLibrary, created the cron task but not working
i think was created correct
adrianwi
You're missing some -- too! Mine looks like this:
jexec calibre-server calibre-server --with-library="/mnt" --port="8282" --username="username" --password="password"
I'd restart the jail, enter the jail shell and check that /mnt displays your calibre library, and if it does, running the edited cron task from the WUI might work.
fontes31
in shell i have -
/mnt/media
fontes31
this is the jail shell
adrianwi
Then it should work with:
jexec calibre-server calibre-server --with-library="/mnt/media/calibreLibrary" --port="8282" --username="username" --password="password"
Although you probably started the calibre server with the previous command (without -- flags) so make sure you restart the jail (by clicking the yellow circle icon underneath the list of jails)
fontes31
I did exactly has you said, but not working
the cron in attachment
my freenas version is 9.3. Should i update to 9.10?
adrianwi
It shouldn't have a one at the start!
Perhaps you didn't install the pkg correctly then. From the jail shell, what does this return > service -e
fontes31
in attachment
adrianwi
So calibre isn't running. I suggest you go back and try installing everything again. Personally, I'd delete the jail and start again.
fontes31
it created as a "standard" jail
running the comand "pkg upgrade" i have "pkg: skipping unknown key 'messages'. Is normal?
adrianwi
Try running pkg update before pkg upgrade.
fontes31
in the end of 'pkg install calibre' i have:
The py27-apsw port currently does not have a maintainer. As a result, it is
more likely to have unresolved issues, not be up-to-date, or even be removed in
the future
fontes31
i have also this error in 'pkg install calibre':
sysctl: unknown oid 'compat.linux.osrelease'
linuxulator is not (kld)loaded, exiting
pkg: PRE-INSTALL script failed
adrianwi
No idea about those, sorry. Perhaps visit the calibre support pages and ask someone there?
