Calibre in the plugin jail
blairjj
MarchHare,
You need to populate the calibre database with your books before there is anything to see:
calibredb add -r /media/ebooks/ --library-path=/media/ebooks
once that is done you can test with:
calibre-server --library-path=/media/ebooks
in my case /mnt/media/ebooks is mounted on my calibre jail as /media/ebooks
blairjj
MarchHare
blairjj
That did it! Thank you!
I'm assuming one would just create a cron job to run this every so often?
blairjj
MarchHare,
I think the cron is a reasonable approach depending on the frequency of the changes in your data set.
blairjj
adrianwi
Managed to get Calibre running in a jail with the help of this thread, but still not sure how I get it to start with the jail
I've got calibre_enable="YES" in /etc/rc.conf which starts fine but not sure how to add the server command as it doesn't seem to like the combinations I've tried.
Did anyone get this starting automatically with the jail?
Also, where can I add a username and password to restrict access?
Thanks
meatservo80
So I had this working with rc.conf settings for like 2 years now and I just migrated to a fresh server. They updated the calibre package where it doesnt work with a cron or rc so far. I currently have to run this manually each jail bootup with the following command. Which works with out issue from CLI. but put it in a cron and it doesnt work.
`calibre-server --with-library /media/calibreLibrary --port 12456 --daemonize`
meatservo80
For anyone else starting out trying to get this working on a new build here is the way I did it as of 20Feb2016 on the latest 9.3 Stable. (Outside of autostart) *I wrote it in markdown thus ignore some of the syntax
#### Calibre **(Works but has to be manually started right now, cron and rc dont work)**
- Add Jail
- Name: calibre_1
- Template: --
- IP to 10.1.10.22 and Gateway to 10.1.10.254 #Yours will be different, I have a gateway because I port forward it to access outside
- **VIMAGE** and **Autostart**
- Add storage - Source /mnt/zpool0/media/Books/Calibre Library to /media/calibreLibrary , **create directory**, **mounted**
SSH to hyrule #my freenas server
sudo jexec calibre_1 csh
pkg update
pkg upgrade
pkg install calibre
vi /etc/rc.conf
Add the following lines (tried calibre like original and now this and both dont work)
calibre-server_enable="YES"
calibre-server_port="12456"
calibre-server_user="root"
calibre-server_library="/media/calibreLibrary/"
**ESC**, `:wq`
**Manually start right now on each reboot of jail**
SSH to hyrule
`sudo jexec calibre_1 csh`
To update
pkg upgrade
adrianwi
Thanks
After playing around with this for several hours and not getting anywhere, I thought I'd start from scratch with the little I'd learnt and hey presto, I've now got Calibre running in a jail with authentication in about 6 simple steps :D
For anyone interested:
1. Create FreeNAS jail (default settings - I called it calibre-server)
2. Enter shell of new jail
3. Run 'pkg upgrade' and then 'pkg install calibre'
4. Add storage to jail (i.e. mount the location of your Calibre library to the jail - I just used /mnt)
5. In the WUI create a Cron Job with the appropriate flags (mine looks like jexec calibre-server calibre-server --with-library="/mnt" --port="8282" --username="username" --password="password") nb: the first calibre-server is the name of your jail!
6. Run the Cron Job
Browse to the IP (with appropriate ":" port number) and after entering your username and password your books will appear!
:D
RoadHazard
blairjj
Possible typo: I believe the correct switch is '--with-library' not '--library-path'. The latter is not a valid option with the caliber-server command.
RoadHazard
Presumably this command needs to be rerun every time new books are added? It appears so; Calibre doesn't show me any new books when I drop them into the library directory. Sounds like another good use for a cron job, unless I'm not doing it right.
meatservo80
The way I do is I only use it as a server for web access to your books. When I need to add books, I just open my windows calibre install that points to same location for metadata, so it updates the database, add my books and close. Then your books will showup. Then I can edit the meta data as I add them and such.
meatservo80
- Add Jail
- Name: calibre_1
- Template: --
pkg update
pkg upgrade
pkg install calibre
vi /etc/rc.conf
**ESC**, `:wq`
SSH to hyrule
To update
pkg upgrade
I found my issue now that I finally got back to fixing this, my rc.conf above was incorrect, also a crontab internal to jail at reboot wont work for some reason but rc does now
vi /etc/rc.conf
calibre_port="12456"
calibre_user="root"
calibre_library="/media/calibreLibrary/"
Lucio
vi /etc/rc.conf
calibre_user="root"
is possible to use port 80? in this way we do not need to put the port after the ip in the address bar (eg to have not 10.1.10.22:12456 but only 10.1.10.22)
meatservo80
Shouldn't be an issue to configure it that way. Just remember if trying to access outside of your internal network, you need to forward that port to calibre jail and since its 80 you have a very large security hole for people to get in.
Lucio
good point, i didn't think before about that. thanks
fontes31
6. Run the Cron Job
:D
after entering 'pkg upgrade' i have this:
pkg: Skipping unknown key 'messages'
is normal?
fontes31
6. Run the Cron Job
:D
I did this mini tutorial but nothing. Is this cron job ok?
jexec calibre-server calibre-server with library="/mnt/tank/media/calibreLibrary" port="8282" username="username" password="password"
my folder of calibreLibrary: mnt/tank/media
my jails: /mnt/tank/media /mnt/media
The jail i created is: calibre-server
adrianwi
You're running the cron job within the jail, so the library="path" needs to be the name of whatever you mounted in the jail storage.
fontes31
my jail storage: /mnt/tank/jails
add storage of the jail: source - mnt/tank/media destination - mnt/media
fontes31
this is my cron job
