Hi
So I've been having fun with poudriere (builds pkgng packages and creates repositories) for some time on normal FreeBSD and now I'm looking at FreeNAS' jails if they can serve some of my needs so that I could just have most of my network hackery (that doesn't need much resources on itself) running on the same FreeNAS box that I intend to get but inside jails for sure.
It seems the standard is 9.2, not exactly native FreeBSD but (likely?) TrueOS, unfortunately this jail template doesn't contain 'freebsd-version' so I'm not exactly sure what userland it uses.
I'd really like to reuse my poudriere VM (it runs my Haswell desktop and is quite fine with building larger stuff) but can I simply build for FreeBSD 9.2 with poudriere and the jails should be happy?
