- May 28, 2011
Are you using a specific brand of thermal paste? If so, which one?
Can you report again, in one nice posting the CPU temps for the following and using the UBCD:
1. Boot the CD, leave it on the menu that it goes to for a few minutes and using the IPMI, what is the CPU temp and CPU fan speed?
2. Now run any CPU Stress Test, watch the CPU temps on IPMI, what is the temp after 5 minutes and 10 minutes, and the fan speeds of course.
I hope for under 40C at idle and under 75C under full load.
Questions about your build...
1. Do you have the cover on the case to promote proper airflow?
2. Do you have sufficient airflow into and out of the motherboard space?
3. Proper airflow is critical. The CPU fan will only recirculate hot air if clean cool air cannot get in and the hot aid is exhausted.
