Kevin Horton
 - Dec 2, 2015
The X10SDV-TLN2F board also has 10GB networking, which might be useful in the future.
			My main concern besides heat with the Xeon, is the 6 SATA ports. I need to use all 6 for my disks.
Do you lose a SATA port if you plug in an M.2?
Part of me wants the 8 core, very low power machine but damn those single core benchmarks are kind of worse than I expected. FreeNAS isn't *that* multi-threaded is it?
This is why I use an m2 boot drive for esxi
Certainly not if it’s a PCIe NVME M.2
Seems pretty multithreaded to me. SMB is not.
In the benchmarks I’ve seen, an avoton c3000 16 core compares favorably with a Xeon D1500 8 core.
Of course, need to consider the Xeon D 2500 as well now.
I am not Stux, but it looks pretty clear to me. The board spec says it supports "Up to 256GB Registered ECC DDR4-2400MHz" and the memory is "DDR4 2400 (PC4 19200) 2Rx8 288-Pin 1.2V ECC Registered RDIMM compatible Memory".sorry to leverage your thread but I need someone smart to outright confirm for me, if these ram sticks (2 pack) would definitely work in the SuperMicro denverton boards.
DDR4, Registered, ECC, 2400; all boxes ticked.
On the other hand some supermicro X10 boards) are mentioned in our forums as RAM-picky... Having said that - this board is not X10. So I guess I am no help here. At least I am not surprised @diskdiddler is looking for sanity check...it looks pretty clear to me.
Other wild guesses, I guess a bit too late...:
- Does the store have some friendly return policy?
 - They claim the product is supermicro compatible so maybe they accept compatibility claims or at least can list tested motherboards?
Sent from my mobile phone
Hi @Stux , I am wondering if you have any IOPS number for your pool? I am also using p3700 as my slog and my sync write IOPS was less than I expected (10K IOPS 4K writes). Now I don't know if there is something wrong with my setup or this is simply how things should be. If you can runThis is why I use an m2 boot drive for esxi
In the benchmarks I’ve seen, anavotondenverton atom c3000 16 core compares favorably with a Xeon D1500 8 core.
 iozone -a -s 512M -O in a sync=always dataset and post the output here that would be really helpful for me. ThanksWill write up the pfSense install eventually.
Two SLOGs might saturate it’s capacity. But better than nothing. And only if it happens together.
So give it a try and monitor it. If you see sustained 90-100% busy then you’re probably saturating the slog.
Your ESXi does zero routing. It's not a router. It's a hypervisor. It does have a "default route" for its own internal operations, but this doesn't affect VM's.
So if you want to have a storage network and a DMZ network and an internal network and an external (upstream) network, you can easily have 4 VLAN's. Configure your switch to present four standard ports ("access mode") on VLAN's 10, 11, 12, and 13, and a trunk port with all 4 VLAN's going to your ESXi. Configure your ESXi vmnic0 to be connected to vSwitch0 (which it should be by default). Then configure vSwitch0 to have a port group on each of VLAN's 10, 11, 12, and 13. You can add VM's to any of these VLAN's and they will be totally isolated from other VLAN's. You can add a VMkernel port group that allows ESXi to access those networks for things like the ESXi NFS client. You can then have an Untangle VM or physical host to handle routing. You attach the networks you need to the systems where you need them.
