Build Report: Node 304 + X10SDV-TLN4F [ESXi/FreeNAS AIO]
Stux
Next, Add "other device" -> PCI Device
And select the AHCI Lynx Point device.
And repeat for your PCIe NVME SLOG device if you have one...
These two devices will be passed directly to the VM. The VM will have bare-metal access to these devices.
Stux
This is what it should look like, of course, your vCPU, Memory and HD size should be different depending on your requirements.
Stux
And now you have a VM ready to start...
Click Power-on... and after the Grub screen, continue to install FreeNAS
You only want to install onto your Virtual Disk. Do not install onto your HDs! Or onto USBs either.
Yes you want to erase all partitions...
You definitely want to Boot via BIOS. ESXi does not support booting via UEFI.
And when that's done...
choose Shutdown System.
And wait for the VM to shutdown...
Stux
Preparing for First Boot after FreeNAS Install
Now, you can Edit the VM...
Might as well remove the CD/DVD, save, then remove the SATA controller. This should in theory provide a minor optimization.
Now that we've booted the VM once, our Network Adapters have MAC addresses. Its very useful to make a note of these to prevent mixing up the interfaces during configuration inside the VM.
And I save a note in the Notes field...
And we can restart.
But when I go to Chrome...
Chrome will sometimes not let you connect to the same IP which was hosted by a different system previously... in this example, my FreeNAS instance has acquired 192.168.0.16 IP, which was used when I first setup the ESXi instance... which means that Chrome has cached the page... I can fix it by clearing my cached downloads...
And now we can log in, import our config, and import our pool :)
Stux
Configuring the vNic Network Interfaces in FreeNAS
Before adding the virtual network interfaces, I'm going to run ifconfig | less in the console shell (9) to display the NICs and their MAC addresses...
Here you can see that vmx0 is vNic1 (ie Storage Network) and vmx1 is vNic2 (ie VM Network). If you add further vNICs, be sure to check the interfaces again because the order can change when you add additional vNICs.
I'll update the notes...
So, first lets add the Storage Network interface (vmx0)
(Its probably a good idea to do the Management network interface first... then you won't have to use the console to correct it!)
Network -> Interfaces, Add Interface
Selecting vmx0, naming it Storage Network and setting the static IP and mask. I'll also add the "mtu 9000" option...
And when I save, I lose connectivity.
Pressing enter in the console, I see that the management IP has changed...
so I guess I need to update the vmx1 interface via the console.
And then it comes good...
ESXi is using jumbo frames for storage, the vSwitch is set to support jumbo, and FreeNAS is now using Jumbo. This does make a performance improvement and will increase throughput from 2-5gbps to 20gbps in internal networking.
Stux
Mirroring your virtual boot disk onto a USB so that you can bare-metal boot FreeNAS
This is optional... but I find it useful to be able to boot into FreeNAS without ESXi. Worst case, if I screw up my ESXi install... I can still get to all my FreeNAS files. I think that's a good safety net.
Now... lets setup bare metal boot again...
Assuming you have a thumb drive you want to bare metal boot off... if that's already got FreeNAS installed... its a good time to either use another thumbdrive... or one of your two mirrors... because the first thing we need to do is erase it.
You need to erase it because FreeNAS will load the boot pool from a USB in preference to the virtual disk on boot... and you can't dynamically add a USB to a VM guest with PCIe pass-through enabled... So we need to shutdown FreeNAS... and if we do that, then the VM will load the boot pool off the USB... which... well.. Just erase the USB.
The easiest way to do this is simply to erase the USB in a normal client PC... say a Windows box... or a mac...
Then shutdown your FreeNAS guest
Next, plugin your erased USB, edit your FreeNAS VM, and add a USB Device
And select the USB drive (its probably defaulted)
Then start the FreeNAS VM again.
...when that finishes booting, login to the GUI, then go to Boot -> Boot Status, select "freenas-boot", and click "attach" at the bottom.
And select the USB (will probabaly be da1)
It will begin resilvering. I like to use the shell to perform zpool status freenas-boot repeatedly to watch the resilver occur...
Once its resilvered, you now have a physical boot mirror which you can use to boot bare-metal.
Shutdown FreeNAS, then Shutdown ESXi...
Stux
Booting FreeNAS Bare-metal.
Next, use the iKVM, to power on the system, and enter BIOS.
Select Boot Mode: Legacy, and make sure the USB Key is the first boot device.
Save and Exit (F4)
And FreeNAS bare-metal should boot.
But the network interface needs to be re-added
ix0 is Port 3
ix1 is Port 4
igb0 is Port 1
igb1 is Port 2.
I want to configure ix0. DO NOT use the same IP address as you use in the ESXi VM, although it will let you, you won't be able to login to the UI when booted inside ESXi.
And you should now be able to login to your bare-metal install.
But your boot volume will be degraded, because the virtual disk is missing.
BUT, that's okay... when you reboot to ESXi it will resilver. If you wanted to you could add a second USB mirror now...
You can shutdown, re-enter BIOS, set Boot Mode to UEFI, save/exit and it will auto-start ESXi.
When ESXi finishes loading, start the FreeNAS VM.
You'll be greeted by a critical alert...
This is just the virtual disk resilvering to catch up with the USB.
will confirm this. 246KB resilvered.
zpool clear freenas-boot will get rid of the warning.
Stux
<reserved>
Stux
Setting up an NFS Datastore
Firstly, lets create an vm_nfs dataset to store our NFS based VMs.
enable atime is off.
Then add an NFS share...
Notice, maproot user/group is root/wheel. Also, Authorized Networks is our storage network.
and enable NFS...
Next, go back to the ESXi GUI.
Datastores -> New datastore
Then select "Mount NFS Datastore"
NFS server is your FreeNAS storage IP. NFS share is the full mount path of the dataset you shared.
Theoretically, you could use NFSv4, and its probably more performant, but this is simpler.
And now you have a mounted nfs data store.
Stux
Setting up an iSCSI datastore in FreeNAS.
First, create a zvol. Use 64KB blocks, its a good compromise.
I like to use sparse zvols... then I can allocate storage as I need it...
And there it is...
Next go to Sharing, iSCSI...
Add a Portal, Initiator, Target, Extent and Associated Targets
Note: IP address is the Storage IP.
Stux
Then startup the iSCSI service...
Enabling iSCSI and mounting an iSCSI datastore in ESXi
Now its time to go to vmware to enable iSCSI...
Rather than mounting an NFS datastore, with iSCSI you need to enable the iSCSi "hba"
Storage -> Adapters, then Configure iSCSI
Enable, and save.
Configure iSCSI, add a dynamic target for your FreeNAS iSCSI address...
close & save...
Configure iSCSI...
Hey look, its now got a static target...
Rescan the Adapters (not refresh), because, it might help.
then go to the devices tab.
You should see the FreeNAS iSCSI disk. It will be degraded. This is because its not multi-homed. Oh well. If you really wanted to you could create another vSwitch and add that and a port group, and all of that... or you could just not worry about it, since its all an internal network anyway.
If you click on the device, then you can create a datastore on it...
Stux
And there we have it...
Now... that's only a 100GB zvol... lets resize it!
Stux
Resizing an iSCSI datastore in ESXi/FreeNAS
So, say you have a 100GB zvol for ESXi and you want to resize it... its pretty simple.
Edit the zvol, to increase its size...
Here i'm growing it from 100G to 200G.
Select the device in ESXi, and click Increase Capacity.
Expand an existing VMFS datastore extent
Select the datastore
Select the device
Select the partition you wish to grow...
Confirm...
And its done...
Stux
In tomorrow's episode... we'll make some VMs ;)
EDIT: or not.
Stux
Adding Swap and L2ARC using Virtual Disks
There is a fast M.2 NVMe disk with 250GB available installed in this system, but the ESXi install and the FreeNAS boot disk only use about 12GB of that. Seems like a waste.
Although, best recommendations are to provide FreeNAS with physical access to disks, the swap and l2arc devices are ephemeral, and thus it doesn't really matter if they are virtual devices.
In my testing, the VMware pass-through virtual devices are quite performant.
So, I'll create a couple of Virtual disks in the FreeNAS VM, and use those for swap and L2ARC.
I'll use a 16GB swap disk, but you could use whatever size you preferred. I'll use a 64GB L2ARC, as I found on a 16GB FreeNAS install, 128GB causes performance issues. The more memory your FreeNAS VM has, then the more L2ARC you can provide.
Increasing either disks size is quite easy in the future, and since everything is virtual, you can just remove and re-add.
I will set the Shares to High. This is the priority that Vmware puts on satisfying the virtual disks i/o requests, and since this is an AIO setup, if FreeNAS is waiting on an L2ARC or Swap request, then everything is.
I will use Thin provisioning for these disks, as the swap will be used only minimally, and thus not take any space unless its being used, and the L2ARC is similar. When shutting down, I believe the disk usage is released.
Also, I will use Independant Persistant provisioning. This means that when you backup the VM it will not backup the L2ARC and Swap disks, which will save space in your backup, and since they are ephemeral that's fine, if you had to restore your VM from backup, it would be trivial to re-create/configure the swap/l2arc volumes.
Firstly, lets create the two Virtual disks. If you are using PCIe pass-through you'll need to shutdown the VM to add disks to it.
Creating the virtual disks
Edit the FreeNAS VM settings, Add hard disk -> New hard disk, twice.
The two new hard disks appear...
As mentioned, two disks, one 64GB and one 16GB, both Thin provisioned, both Independent - persistent, and both with Shares set to High.
The disks will tell you their SCSI controller ID (ie 0:2 and 0:3), if you wanted to re-arrange the device ordering in FreeNAS, you can do that by adjusting the controller order.
Next save and boot your VM.
Once booted, you can see the disks in Storage -> View Disks.
It may be a good idea to use the Description field to label the swap disk, the l2arc disk will no longer be present once you add it to a pool, but the swap disk will always be present.
Adding L2ARC
Adding the l2arc disk is trivial.
Storage -> Volumes, Volume Manager
Then in the Volume Manager
Select the Volume to Extend, add the L2ARC disk, and ensure you've set it's type to Cache. When you're sure that everything is right, hit Extend Volume.
And your L2ARC has been added. Congratulations.
You can confirm this by clicking on the Volume Status icon, which you get to by going to Storage -> Volumes, selecting the top level of your pool, and its down the bottom of the screen...
and the volume status with cache on da2p1
NOTE: when booting bare metal, your pool might not mount without being forced to mount, since the virtual L2ARC is missing. If you wanted to, you could offline or remove the l2arc before rebooting.
Stux
Adding a non-pool swap device
The virtual swap device is a little bit trickier than the L2ARC as you need to use the command line.
I documented the generalized instructions for adding any partition or disk as swap in a FreeNAS system, as well as how to temporarily disable the built-in pool based swap devices (which are prone to crashing your server if a disk should fail)
Resource: How to relocate swap to an SSD or other partition
In this case, "da3" is my swap disk. If you get an error on the gpt create, you selected the wrong disk!
root@freenas:~ # gpart create -s gpt da3
da3 created
root@freenas:~ # gpart add -i 1 -t freebsd-swap da3
da3p1 added
root@freenas:~ # glabel status | grep da3
gptid/4fab0ae9-889f-11e7-be79-000c290148d6	 N/A  da3p1
And that's the swap disk initialized and ready to use. My gptid id is "4fab0ae9-889f-11e7-be79-000c290148d6"
So next I add a Post-Init command with the following:
swapoff -a ; grep -v -E 'none[[:blank:]]+swap[[:blank:]]' /etc/fstab > /etc/fstab.new && echo "/dev/gptid/4fab0ae9-889f-11e7-be79-000c290148d6.eli none swap sw 0 0" >> /etc/fstab.new && mv /etc/fstab.new /etc/fstab ; swapon -a
Note: I changed the gptid in the post-init command to match my gptid.
And that will now disable pool based swap and enable the virtual hd swap on restart.
If you don't want to re-start immediately, you can just run the same command in a shell.
And if you look at the system console, you'll also see the pool swap devices were disabled, and the new swap device was enabled...
And finally, in top / Display System Processes, you can see the swap is available too.
Stux
Thermal Testing
Before coming up with the final fan design and fan control settings I had to do some thermal testing
I showed some of that in this post
I'm running tmux, with the fan controller in the primary pane, solnet array tester, mprime and cpu temperature logging. I performed these tests on bare metal so that mprime would have access to all the cores/threads for maximum utilization, and also for access to all the core temperatures.
As a result of this early testing I decided to upgrade the Exhaust fan to the Noctua 140mm.
Its good to know that my HD and CPU temps are now very reasonable at idle, with my fans spinning at their low setting, and very quiet.
And flatout, the CPU doesn't tend to go above 73C, and the HDs won't go past 40C. And that's with 7200rpm drives.
Even flatout, its not objectionable anymore.
A success.
Chris Moore
Thermal Testing
A success.
Nice documentation. Thanks!
More tomorrow?
Stux
LIGISTX
#wow
