Where can I find this script?If you would like an easy way to track and record drive failure and temp data, look into the script I just finished writing (with help from several others here)
Look under Resources -> Multi-Report.
Creating the new file...
Humm, kind of slow...
Do you have enough RAM? Looks like about 8KB. Troubleshooting...
Holy Cow! I found the problem, the system was identified as a Tandy TRS-80 Model 1
Adjusting for the 1.774 MHz clock rate...
Success!
Nope, it's an attempt at humor. You must not be old enough to remember the Tandy Radio Shack TRS-80 super computer.My bad. I thought that was an option in TrueNAS. It's on this forum.
I ran the script. Do I have to worry about this?
Date,Time,Device ID,Drive Type,Serial Number,SMART Status,Temp,Power On Hours,Wear Level,Start Stop Count,Load Cycle,Spin Retry,Reallocated Sectors,ReAllocated Sector Events,Pending Sectors,Offline Uncorrectable,UDMA CRC Errors,Seek Error Rate,Multi Zone Errors,
Far from FAN
2022/09/03,12:50:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,12:50:01,ada1,HDD,PK2338P4HJP63C,PASSED,54,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,12:50:01,ada2,HDD,PK2331PAJL17LT,PASSED,54,177,---,21,22,0,0,0,0,0,0,0,---,
Near FAN
2022/09/03,12:50:01,ada3,HDD,PK2331PAG96LST,PASSED,46,177,---,21,22,0,0,0,0,0,0,0,---,
2022/09/03,12:50:01,ada4,HDD,PCKVT1PB,PASSED,44,24810,---,72,1086,0,0,0,0,0,0,0,---,
2022/09/03,12:50:01,ada5,HDD,P4HE767B,PASSED,45,24619,---,68,1075,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/03,12:00:01,ada0,HDD,PK2331PAJ9975T,PASSED,48,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,12:00:01,ada1,HDD,PK2338P4HJP63C,PASSED,55,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,12:00:01,ada2,HDD,PK2331PAJL17LT,PASSED,54,177,---,21,22,0,0,0,0,0,0,0,---,
Near FAN
2022/09/03,12:00:01,ada3,HDD,PK2331PAG96LST,PASSED,46,177,---,21,22,0,0,0,0,0,0,0,---,
2022/09/03,12:00:01,ada4,HDD,PCKVT1PB,PASSED,44,24810,---,72,1086,0,0,0,0,0,0,0,---,
2022/09/03,12:00:01,ada5,HDD,P4HE767B,PASSED,45,24620,---,68,1075,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/03,13:05:34,ada0,HDD,PK2331PAJ9975T,PASSED,48,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:05:34,ada1,HDD,PK2338P4HJP63C,PASSED,55,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:05:34,ada2,HDD,PK2331PAJL17LT,PASSED,54,177,---,21,22,0,0,0,0,0,0,0,---,
Near FAN
2022/09/03,13:05:34,ada3,HDD,PK2331PAG96LST,PASSED,46,177,---,21,22,0,0,0,0,0,0,0,---,
2022/09/03,13:05:34,ada4,HDD,PCKVT1PB,PASSED,44,24811,---,72,1086,0,0,0,0,0,0,0,---,
2022/09/03,13:05:34,ada5,HDD,P4HE767B,PASSED,46,24620,---,68,1075,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/03,13:10:01,ada0,HDD,PK2331PAJ9975T,PASSED,48,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:10:01,ada1,HDD,PK2338P4HJP63C,PASSED,55,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:10:01,ada2,HDD,PK2331PAJL17LT,PASSED,54,177,---,21,22,0,0,0,0,0,0,0,---,
Near FAN
2022/09/03,13:10:01,ada3,HDD,PK2331PAG96LST,PASSED,46,177,---,21,22,0,0,0,0,0,0,0,---,
2022/09/03,13:10:01,ada4,HDD,PCKVT1PB,PASSED,44,24811,---,72,1086,0,0,0,0,0,0,0,---,
2022/09/03,13:10:01,ada5,HDD,P4HE767B,PASSED,45,24620,---,68,1075,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/03,13:20:01,ada0,HDD,PK2331PAJ9975T,PASSED,48,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:20:01,ada1,HDD,PK2338P4HJP63C,PASSED,55,177,---,19,20,0,0,0,0,0,0,0,---,
2022/09/03,13:20:01,ada2,HDD,PK2331PAJL17LT,PASSED,54,177,---,21,22,0,0,0,0,0,0,0,---,
Near FAN
2022/09/03,13:20:01,ada3,HDD,PK2331PAG96LST,PASSED,47,177,---,21,22,0,0,0,0,0,0,0,---,
2022/09/03,13:20:01,ada4,HDD,PCKVT1PB,PASSED,45,24811,---,72,1086,0,0,0,0,0,0,0,---,
2022/09/03,13:20:01,ada5,HDD,P4HE767B,PASSED,46,24620,---,68,1075,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/04,14:10:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:10:01,ada1,HDD,PK2338P4HJP63C,PASSED,51,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:10:01,ada2,HDD,PK2331PAJL17LT,PASSED,50,202,---,22,23,0,0,0,0,0,0,0,---,
Near FAN
2022/09/04,14:10:01,ada3,HDD,PK2331PAG96LST,PASSED,45,202,---,22,23,0,0,0,0,0,0,0,---,
2022/09/04,14:10:01,ada4,HDD,PCKVT1PB,PASSED,43,24836,---,73,1087,0,0,0,0,0,0,0,---,
2022/09/04,14:10:01,ada5,HDD,P4HE767B,PASSED,45,24645,---,69,1076,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/04,14:20:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:20:01,ada1,HDD,PK2338P4HJP63C,PASSED,50,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:20:01,ada2,HDD,PK2331PAJL17LT,PASSED,50,202,---,22,23,0,0,0,0,0,0,0,---,
Near FAN
2022/09/04,14:20:01,ada3,HDD,PK2331PAG96LST,PASSED,45,202,---,22,23,0,0,0,0,0,0,0,---,
2022/09/04,14:20:01,ada4,HDD,PCKVT1PB,PASSED,44,24836,---,73,1087,0,0,0,0,0,0,0,---,
2022/09/04,14:20:01,ada5,HDD,P4HE767B,PASSED,45,24645,---,69,1076,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/04,14:30:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:30:01,ada1,HDD,PK2338P4HJP63C,PASSED,51,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:30:01,ada2,HDD,PK2331PAJL17LT,PASSED,50,202,---,22,23,0,0,0,0,0,0,0,---,
Near FAN
2022/09/04,14:30:01,ada3,HDD,PK2331PAG96LST,PASSED,45,202,---,22,23,0,0,0,0,0,0,0,---,
2022/09/04,14:30:01,ada4,HDD,PCKVT1PB,PASSED,44,24836,---,73,1087,0,0,0,0,0,0,0,---,
2022/09/04,14:30:01,ada5,HDD,P4HE767B,PASSED,45,24645,---,69,1076,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/04,14:40:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,202,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:40:01,ada1,HDD,PK2338P4HJP63C,PASSED,51,203,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:40:01,ada2,HDD,PK2331PAJL17LT,PASSED,50,203,---,22,23,0,0,0,0,0,0,0,---,
Near FAN
2022/09/04,14:40:01,ada3,HDD,PK2331PAG96LST,PASSED,45,203,---,22,23,0,0,0,0,0,0,0,---,
2022/09/04,14:40:01,ada4,HDD,PCKVT1PB,PASSED,44,24836,---,73,1087,0,0,0,0,0,0,0,---,
2022/09/04,14:40:01,ada5,HDD,P4HE767B,PASSED,45,24645,---,69,1076,0,0,0,0,0,0,0,---,
Far from FAN
2022/09/04,14:50:01,ada0,HDD,PK2331PAJ9975T,PASSED,47,203,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:50:01,ada1,HDD,PK2338P4HJP63C,PASSED,51,203,---,20,21,0,0,0,0,0,0,0,---,
2022/09/04,14:50:01,ada2,HDD,PK2331PAJL17LT,PASSED,50,203,---,22,23,0,0,0,0,0,0,0,---,
Near FAN
2022/09/04,14:50:01,ada3,HDD,PK2331PAG96LST,PASSED,45,203,---,22,23,0,0,0,0,0,0,0,---,
2022/09/04,14:50:01,ada4,HDD,PCKVT1PB,PASSED,44,24836,---,73,1087,0,0,0,0,0,0,0,---,
2022/09/04,14:50:01,ada5,HDD,P4HE767B,PASSED,45,24645,---,69,1076,0,0,0,0,0,0,0,---,
| Date | Time | Device ID | Drive Type | Serial Number | SMART Status | Temp | Power On Hours | Wear Level | Start Stop Count | Load Cycle | Spin Retry | Reallocated Sectors | ReAllocated Sector Events | Pending Sectors | Offline Uncorrectable | UDMA CRC Errors | Seek Error Rate | Multi Zone Errors |
You are right. In any case, the only value of interest is the one after "PASSED", which is the temp of the drive.While I understand the format of the data, most of the users here don't necessarily use my script so clearly identifying the data would be helpful to the group.
Here is the format:
Date Time Device ID Drive Type Serial Number SMART Status Temp Power On Hours Wear Level Start Stop Count Load Cycle Spin Retry Reallocated Sectors ReAllocated Sector Events Pending Sectors Offline Uncorrectable UDMA CRC Errors Seek Error Rate Multi Zone Errors
2022/09/17,15:55:02.10,sda,HDD,PK2331PAJ9975T,PASSED,44,499,---,23,28,0,0,0,0,0,0,0,---,
2022/09/17,15:55:02.10,sdb,HDD,PK2338P4HJP63C,PASSED,41,499,---,23,30,0,0,0,0,0,0,0,---,
2022/09/17,15:55:02.10,sdc,HDD,PK2331PAJL17LT,PASSED,40,499,---,25,30,0,0,0,0,0,0,0,---,
2022/09/17,15:55:02.10,sdd,HDD,PK2331PAG96LST,PASSED,44,499,---,25,30,0,0,0,0,0,0,0,---,
2022/09/17,15:55:02.10,sde,HDD,PCKVT1PB,PASSED,42,25133,---,76,1099,0,0,0,0,0,0,0,---,
2022/09/17,15:55:02.10,sdf,HDD,P4HE767B,PASSED,42,24942,---,72,1088,0,0,0,0,0,0,0,---,
It very well may be the smart move, to move the two upper drives into the air flow. The other option which requires more creativity is to use some think by firm cardboard to make internal louvers to direct the airflow exactly where you need it to go. The tricky part about home made louvers is mounting them in the case. While it may not look great, the object is to ensure the drives stay cool.It does seem as if the 2 hottest drives might just be out of the flow of air. Perhaps if I move them "lower" (see picture), it might reduce the temps.
