Bug? Sidebar System Settings blank when on Dashboardsite
Marv21
Is it just me, or are there no System Settings (Update, General, etc) when you open the Sidebar and are on the Dashboard?
on every other Page i see the submenus.
Kris Moore
SVP of Engineering
Administrator
Not seeing this here. What browser / OS? Any extensions installed? Might be worth trying latest Chrome to see if its still failing, otherwise a bug ticket on https://jira.ixsystems.com with those details will help us dig into this.
Samuel Tai
Clear your browser cache. Upgrades are known to cause wonky display issues due to cached scripts from older versions.
mervincm
In earlier web days - clear your cache was a commonly used tool to deal with site ... weirdness. I go months now without needing to. Is it not fair to say that this shows a degree of ... immaturity? in the product, something to target for improvement?
Marv21
So i tried it with Windows 10 (on two different PCs) and 7.
I cleared Cache on the Browser i tried (Firefox, Chrome and Brave).
Everywhere I have the same Bug. But if you dont have it - it has to be in my TrueNas Scale installation.
What happens when you change the scaling options in Windows and/or change the amount of zoom in the web browser?
Marv21
Same "bug".
My scaling options are 100%, i tried something else, but i never touched these setting...
Tried zoom with ?STRG+Mousewheel? - that didnt help either...
Samuel Tai
Are you by chance running NoScript or other plugin that blocks JavaScript?
Marv21
Indeed in run it on my main Computer, but not on the other two :(.
Its a Mystery.
Samuel Tai
Are you running some sort of proxy server in your environment, like AdGuard Home, which could be blocking the JavaScript needed for the side bar?
Marv21
No nothing.
The sidebar is working on every Page except the Dashboard Page.
