Omri Traugott
 - Mar 3, 2019
Hey All i am very new to all this NAS stuff.. So thanks in advance.
i read that most if not all of you recommended to use 2nd hand parts for you first build, witch i like the idea very much.
the only problem with used 2nd hand parts in my country is that usually its buying full PCs. and AMAZON / eBay is not relay a valid option (4-5 weeks shipping and shipping costs). and i am relay bad at understating what is working good.
My needs are very basic i think, General file storage (with raid) , Plex media sharing (if possible), as well as the use of transmission for Torrenting.
intel core i3-7100 kaby lake dual-core 3.9 ghz
lga 1151 b250 ddr4 2400mhz asrock
lenovo 8gb ddr4 2400mhz - x2 (16Gb)
samsung 256 m.2 pm961
this is one option i can purchases form some guy, including a case & 1TB HDD (i will wand to upgrade to 2 HDD of 4Tb each) all for 350USD.
i will add some more that i can find.
will this support / be sufficient to run FreeNAS for 4-5 years??
thanks!
thanks!
