theOneAndOnlyMrT
- Jan 13, 2017
I recently got all of my hardware and have been following the break in procedure from the forum. I completed the memtest (ran it for 24hours). It did 6 total tests and no errors. I changed the fans through IPMI to Full. I then moved on to the CPU test (keeping fans on Full) and it is hovering at around 71/72 degrees celsius. Is this normal? That seems high to me.
Motherboard: Supermicro x11ssm-f
CPU: Xeon X3-1240 v5
Are those temperatures acceptable? Do I need to keep the fan on Full to ensure it stays low? (on full, the noise doesn't bother me so that's not a problem)
