ChapterSevenSeeds
- Dec 26, 2021
Hey folks. I have an 8x 6TB RAIDZ2 pool that has been great for over a year now. All 8 of my drives are still under warranty. Now, just earlier today, my bimonthly scrub showed that a drive suffered 138 read errors. The last SMART test that ran on the drive was a quick test on January 1st. That test says that there were read errors:
However, the top of the SMART data section says this:
What is the best thing to do at this point? Should I immediately run an extended SMART test? Replace the drive?
And, when it comes to replacing a drive, when said drive is still under warranty, what is the best, safest, and most cost efficient way to replace it with a new one? I have a few ideas:
# 1 Short offline Completed: read failure 90% 27132 1528286552However, the top of the SMART data section says this:
SMART overall-health self-assessment test result: PASSEDWhat is the best thing to do at this point? Should I immediately run an extended SMART test? Replace the drive?
- Submit an RMA and wait for a replacement drive. My fears with this method are that my pool will go for an extended period of time with a missing drive. The last time I sent a drive for RMA, it took over a month for the manufacturer to finally ship the replacement. I would imagine that this is the cheapest but also the least safe method.
- The same as the above but while waiting for the RMA replacement, buying a replacement drive for quick insertion into the pool while waiting for the RMA drive to be shipped and using it as a spare once it arrives.
- Keep a spare drive on hand and use it immediately once the faulty drive starts to show. Then use the RMA drive as the new spare once it is shipped. The only thing I don't like about this method is that the warranty of the spare drive will fade away while it's not in use. If money wasn't a concern, this would be my go-to method.
- Same as the above but instead of waiting for the RMA replacement drive to arrive to act as the new spare, I'd just purchase a new spare immediately after inserting the new one. Essentially, I'd always have one spare on hand with a gap of a few days at most.
