I have Jellyfin, 4 TV channels rendering through ErsatzTV, and a Minecraft Server (Crafty Controller) all running as apps on TrueNAS Scale. All media is 1080p or lower at the moment and the TV stations are broadcasting at 720p however I would like to increase it back to 1080p, and all media is encoded in either h.264 or h.265.
For starters, I was wondering if and how helpful it would be to offload all media transcoding, decoding, and graphical work to a GPU and take the pressure off the CPU. And, if this is a solid solution, what GPU would you recommend that is supported by TrueNAS Scale and can be passed into the three apps listed above and enabled with hardware acceleration? I would prefer a cheaper solution even something that is widely available from the used market will do.
Thanks!
Thanks!
