SOLVED Bad controller? (No - ASRock mb shipped with ancient BIOS)
jonl
Hi folks - I built out a new system and as I move data onto it I'm seeing a couple things that seem to indicate controller issues. If you could help confirm that, and assess if these are replace-it-worthy that'd be awesome.
Controller: LSI 6Gbps SAS HBA LSI 9201-8i
The 8 drives are split between two SFF-8087 ports/cables, so if it's a cable problem it's either both uniformly, or the controller.
First, I'm getting these notifications (scale) periodically (typically after boot, but here and there during runtime also): Warning: Critical Interrupt #0xfe Asserted Bus Degraded.
It's an asrock rack mb, and from the IPMI I can see the source event:
IDRecord TypeTime StampGenID(Low)GenID(High)EvMRevSensor TypeSensor #EvtDir TypeEvent Data1Event Data2Event Data3
025fh02h645a802fh01h00h04h13hfeh6fhabh01h01h
Event Data1 Bus Degraded
Event Data2 Bus number: 0x01
Event Data3 Link speed degraded
Second, I'm also seeing checksum errors that manifest uniformly across all 8 drives on that controller.
❯ sudo zpool status -v data
  pool: data
 state: ONLINE
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 0B in 14:27:35 with 1 errors on Tue May  9 22:35:13 2023
    NAME                                      STATE     READ WRITE CKSUM
    data                                      ONLINE       0     0     0
      raidz2-0                                ONLINE       0     0     0
        ab020c34-c835-4400-8600-7602eb70daab  ONLINE       0     0     2
        19d49ffb-60d8-4613-b34a-574d2666d603  ONLINE       0     0     2
        339c8b3b-01ea-467e-bdb6-25086b937e1e  ONLINE       0     0     2
        6a7e094f-9fb7-42ba-9c16-1bf3d5768a39  ONLINE       0     0     2
        f92c134b-0a3d-430e-aa7e-f89a34afa9c6  ONLINE       0     0     2
        eccd1f92-f822-4da3-ac44-3ed73af98e71  ONLINE       0     0     2
        8c4a1def-4d8f-4834-b102-417807f8e469  ONLINE       0     0     2
        26ee378e-1893-467a-9951-cd27d199e3fb  ONLINE       0     0     2
I had 10 the last time, but cleared them to see if they'd recur.
Here's the smartctl output for a couple of drives in the array in case it's useful:
❯ sudo smartctl --all /dev/sde
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Device Model:     ST18000NM000J-2TV103
Serial Number:    ZR5BKMDK
LU WWN Device Id: 5 000c50 0e52bad24
Firmware Version: SN02
User Capacity:    18,000,207,937,536 bytes [18.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed May 10 07:19:05 2023 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (  567) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      (1537) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x70bd)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       168337720
  3 Spin_Up_Time            0x0003   091   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       20
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   085   060   045    Pre-fail  Always       -       319507513
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       5501
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       20
 18 Unknown_Attribute       0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   067   055   000    Old_age   Always       -       33 (Min/Max 31/40)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       9
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1057
194 Temperature_Celsius     0x0022   033   045   000    Old_age   Always       -       33 (0 21 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       5451 (212 132 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       121194232748
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       97375998482082
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      5430         -
❯ sudo smartctl --all /dev/sdg
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 870 EVO 2TB
Serial Number:    S6PNNS0T808464E
LU WWN Device Id: 5 002538 f3280338d
Firmware Version: SVT02B6Q
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
Local Time is:    Wed May 10 07:19:08 2023 PDT
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    been run.
data collection:         (    0) seconds.
capabilities:              (0x53) SMART execute Offline immediate.
                    command.
                    No Offline surface scan supported.
                    power-saving mode.
recommended polling time:      ( 160) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       5500
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       20
177 Wear_Leveling_Count     0x0013   093   093   000    Pre-fail  Always       -       152
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   079   053   000    Old_age   Always       -       21
195 ECC_Error_Rate          0x001a   200   200   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
235 POR_Recovery_Count      0x0012   099   099   000    Old_age   Always       -       7
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       164059180752
252 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
  256        0    65535  Read_scanning was never started
WN1X
Have you tried cleaning the contacts and reseating the HBA board?
jonl
Thanks - done. Saw the same bus errors on the subsequent boot (also while I hadn't cleaned it until just now, I've reseated it a few times for various reasons with errors before/after)
jgreco
Resident Grinch
Check the temperature of the heatsink on the HBA. LSI's controllers are known for throwing random errors if they are running too hot. See point #8 in the following article --
and note that front to back airflow is very necessary for these controllers.
jonl
Check the temperature of the heatsink on the HBA. ... front to back airflow is very necessary for these controllers.
Thanks -- This asrock rack board needs some amount of manual fan configuration, and I was just thinking about how I was putting a lot of attention into making sure my CPU "fan" was correct but I never configured anything for the other fans. The controller heatsink was certainly warm to the touch but not hot hot, though perhaps enough be a problem. I'll see about configuring temp sensors/case fan mappings to improve the cooling.
Current temps (via IPMI) are 26-34 (deg C) across CPU/card side/mb.
jonl
I'm still working on the fan config, but I'm getting the bus asserts on boot even after doing some other checks (that allowed everything to cool down if >30 is problematic.)
Art of Server was gracious enough to consider the problem and suggested I check the pins in the slot and processor socket for anything out of place, and to ensure the cooler is tightened evenly when I reseated the processor. They also suggested I could set the link speed for slot 4/6 to "gen 2" or equivalent to skip any link speed negotiation problems, all of which I did and still the bus asserts remain.
jonl
Update - Art of Server sent me another controller to try, but that didn't do it, so I contacted ASRock support who provided a BIOS update (upgraded from 0.02 to 2.11) which resolved the issue.
After I asked, there is also a BMC update (0.01 to 1.02.) Why these aren't on their website I have no idea.
WN1X
Glad to hear you were able to resolve the problems.
