Joshua Parker Ruehlig
- Dec 5, 2011
basically all my settings were default except 'cpu affinity = 0x55'.Hmm. Could be, I just rebooted but I am still capped at 180. Care to share your settings? Are you saying that when you rebooted that you went up to 280 but then dropped again after a while?
I used algorithm variation 1(Hardware AES). I'm not sure if you tried forcing different algorithm variations, but that might change things as well.
So for my e3-1240v2 system, it is actually a FreeBSD server I use to host some stuff, including my security camera system (zoneminder), in a jail. Which uses alot of cpu cycles since it is analyzing 5 HD camera streams. I temporarily disabled zoneminder to test my max hashrate on the system. I noticed I was getting 280h/s on the system, but when I ran xmrig in a jail I got 160-180h/s max. I was confused, tweaking everything, but after rebooting I got 280h/s in a jail as expected.
That was at least a week ago, unfortunately I don't know what hashrate the system can currently max out at, since I normally run zoneminder which keeps the system is busy, and I get 100h/s or less.
It doesn't sound like rebooting does anything in your case, my case might have been something else unrelated, or specific to my setup.
