- Feb 15, 2014
I just discovered the forum is doing autocorrect on "FreeNAS". The problem is that it's applying it to CMD-tagged text as well, with the result being that
freenas-boot is rendered as you see here. If you open the markup for this post, you'll see it's written in lowercase, but ends up displayed in a pretty format. A clueless user then has to figure out that his boot pool is written in all-lowercase, which is less than optimal.
