***version 11.1U7*****
I have a stripe pool with 2 discs.(the data on this pool has no importance,its the FTP for my IP cameras)
for the past week i have been getting
Should I destroy the pool and run a full 0 pass to remap the bad sectors and rebuild the pool?
Or unmount the pool then do an all 0 wipe on the disc to try to keep the pool intact?
If I take option 2 and use the Unmount command after wiping the disc; Will it be able to remount on reboot?
Is there another way to fix bad sectors on a disc?
Any feedback would be helpful.
pool: STRIPE
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0 days 00:12:49 with 2 errors on Mon Dec 2 17:16:59 2019
NAME STATE READ WRITE CKSUM
STRIPE ONLINE 4 0 0
gptid/ffc0194e-9575-11e9-89a2-e0071bfffaff ONLINE 0 0 0
gptid/02986c3c-9576-11e9-89a2-e0071bfffaff ONLINE 4 0 4Should I destroy the pool and run a full 0 pass to remap the bad sectors and rebuild the pool?
root@freenas:~ # zfs list STRIPE 157G 1.60T 157G /mnt/STRIPE
root@freenas:~ # zfs list -r /mnt/STRIPE NAME USED AVAIL REFER MOUNTPOINT STRIPE 157G 1.60T 157G /mnt/STRIPE
