I just added 3 drives to my Supermicro x7DBN/SC926TQ-R800LPB server (9 drives were already present). At first only one of the drives was recognized. I powered off the server and reseated the SATA cables between the chassis and the AOC-SA2-MV8 card (which these slots connect to) and powered it back on. All drives were then recognized OK, and everything is working OK.
However, I noticed some aprobe errors in dmesg when it booted, and I'm not sure what device they are referring to. I'm booting from a Sandisk Cruzer USB drive.
How can I tell what device it is talking about?
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p4 #0 r262572+17a4d3d: Wed Apr 23 10:09:38 PDT 2014
root@build3.ixsystems.com:/tank/home/jkh/build/9.2.1/freenas/os-base/amd64/fusion/jkh/9.2.1/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (2500.05-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x10676 Family = 0x6 Model = 0x17 Stepping = 6
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0xce3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,DCA,SSE4.1>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant, performance statistics
real memory = 34359738368 (32768 MB)
avail memory = 33163694080 (31627 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <PTLTD APIC >
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 2 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ioapic1 <Version 2.0> irqs 24-47 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <PTLTD RSDT> on motherboard
acpi0: Power Button (fixed)
unknown: I/O range not supported
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 2.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 0.0 on pci1
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci2
pci4: <ACPI PCI bus> on pcib4
em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x2000-0x201f mem 0xd8800000-0xd881ffff irq 18 at device 0.0 on pci4
em0: Using an MSI interrupt
em0: Ethernet address: 00:30:48:33:06:f2
em1: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x2020-0x203f mem 0xd8820000-0xd883ffff irq 19 at device 0.1 on pci4
em1: Using an MSI interrupt
em1: Ethernet address: 00:30:48:33:06:f3
pcib5: <ACPI PCI-PCI bridge> at device 0.3 on pci1
pci5: <ACPI PCI bus> on pcib5
mvs0: <Marvell 88SX6081 SATA controller> port 0x3000-0x30ff mem 0xd8200000-0xd82fffff irq 28 at device 2.0 on pci5
mvs0: Gen-II, 8 3Gbps ports, Port Multiplier supported
mvsch0: <Marvell SATA channel> at channel 0 on mvs0
mvsch1: <Marvell SATA channel> at channel 1 on mvs0
mvsch2: <Marvell SATA channel> at channel 2 on mvs0
mvsch3: <Marvell SATA channel> at channel 3 on mvs0
mvsch4: <Marvell SATA channel> at channel 4 on mvs0
mvsch5: <Marvell SATA channel> at channel 5 on mvs0
mvsch6: <Marvell SATA channel> at channel 6 on mvs0
mvsch7: <Marvell SATA channel> at channel 7 on mvs0
pcib6: <ACPI PCI-PCI bridge> at device 4.0 on pci0
pci6: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> at device 6.0 on pci0
pci7: <ACPI PCI bus> on pcib7
pci0: <base peripheral> at device 8.0 (no driver attached)
pcib8: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pci8: <ACPI PCI bus> on pcib8
pcib9: <PCI-PCI bridge> at device 0.0 on pci8
pci9: <PCI bus> on pcib9
pcib10: <PCI-PCI bridge> at device 0.0 on pci9
pci10: <PCI bus> on pcib10
em2: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x4000-0x401f mem 0xd8a20000-0xd8a3ffff,0xd8a00000-0xd8a1ffff irq 33 at device 0.0 on pci10
em2: Using an MSI interrupt
em2: Ethernet address: 00:15:17:7c:bc:81
em3: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x4020-0x403f mem 0xd8a60000-0xd8a7ffff,0xd8a40000-0xd8a5ffff irq 32 at device 0.1 on pci10
em3: Using an MSI interrupt
em3: Ethernet address: 00:15:17:7c:bc:80
pcib11: <PCI-PCI bridge> at device 1.0 on pci9
pci11: <PCI bus> on pcib11
em4: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x5000-0x501f mem 0xd8b20000-0xd8b3ffff,0xd8b00000-0xd8b1ffff irq 34 at device 0.0 on pci11
em4: Using an MSI interrupt
em4: Ethernet address: 00:15:17:7c:bc:83
em5: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0x5020-0x503f mem 0xd8b60000-0xd8b7ffff,0xd8b40000-0xd8b5ffff irq 33 at device 0.1 on pci11
em5: Using an MSI interrupt
em5: Ethernet address: 00:15:17:7c:bc:82
uhci0: <Intel 631XESB/632XESB/3100 USB controller USB-1> port 0x1800-0x181f irq 17 at device 29.0 on pci0
usbus0 on uhci0
uhci1: <Intel 631XESB/632XESB/3100 USB controller USB-2> port 0x1820-0x183f irq 19 at device 29.1 on pci0
usbus1 on uhci1
uhci2: <Intel 631XESB/632XESB/3100 USB controller USB-3> port 0x1840-0x185f irq 18 at device 29.2 on pci0
usbus2 on uhci2
ehci0: <Intel 63XXESB USB 2.0 controller> mem 0xd8d00000-0xd8d003ff irq 17 at device 29.7 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
pcib12: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci12: <ACPI PCI bus> on pcib12
vgapci0: <VGA-compatible display> port 0x6000-0x60ff mem 0xd0000000-0xd7ffffff,0xd8c00000-0xd8c0ffff irq 18 at device 1.0 on pci12
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel 63XXESB2 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1860-0x186f at device 31.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ahci0: <Intel ESB2 AHCI SATA controller> port 0x18a0-0x18a7,0x1874-0x1877,0x1878-0x187f,0x1870-0x1873,0x1880-0x189f mem 0xd8d00400-0xd8d007ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.10 with 6 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
ipmi0: <IPMI System Interface> port 0xca2-0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: console (115200,n,8,1)
fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
ichwd0 on isa0
wbwd0: <Winbond 83627HF/F/HG/G Rev. UD-A> at port 0x2e-0x2f on isa0
wbwd0: Before watchdog attach: Watchdog enabled. Scaling by 60s, timer at 5 (<=300s left). CRF5 0x08 CRF7 0xc0
ipmi1: <IPMI System Interface> on isa0
device_attach: ipmi1 attach returned 16
orm0: <ISA Option ROM> at iomem 0xc0000-0xcafff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe000930edc0 with IPv6 initialized (100409)
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ipmi0: IPMI device rev. 1, firmware rev. 1.60, version 2.0
ipmi0: Number of channels 8
ipmi0: Attached watchdog
ada0 at mvsch0 bus 0 scbus0 target 0 lun 0
ada0: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada0: Serial Number W1F4YELN
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at mvsch1 bus 0 scbus1 target 0 lun 0
ada1: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada1: Serial Number W1F51E58
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at mvsch2 bus 0 scbus2 target 0 lun 0
ada2: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada2: Serial Number W1F509KF
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad8
ada3 at mvsch3 bus 0 scbus3 target 0 lun 0
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
ada3: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device
ada3: Serial Number WD-WCC4N0HT70SL
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
ada4 at mvsch4 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device
ada4: Serial Number WD-WCC4N5PRFUEL
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada4: Command Queueing enabled
ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad12
ada5 at mvsch5 bus 0 scbus5 target 0 lun 0
ada5: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device
ada5: Serial Number WD-WCC4N5PRFK1E
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 2048bytes)
ada5: Command Queueing enabled
ada5: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada5: quirks=0x1<4K>
ada5: Previously was known as ad14
ada6 at ahcich0 bus 0 scbus9 target 0 lun 0
ada6: <ST3000DM001-1CH166 CC27> ATA-9 SATA 3.x device
ada6: Serial Number Z1F4111J
ada6: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada6: quirks=0x1<4K>
ada6: Previously was known as ad20
ada7 at ahcich1 bus 0 scbus10 target 0 lun 0
ada7: <ST3000DM001-1CH166 CC27> ATA-9 SATA 3.x device
ada7: Serial Number W1F3V65G
ada7: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada7: Command Queueing enabled
ada7: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada7: quirks=0x1<4K>
ada7: Previously was known as ad22
ada8 at ahcich2 bus 0 scbus11 target 0 lun 0
ada8: <ST3000DM001-1CH166 CC26> ATA-8 SATA 3.x device
ada8: Serial Number W1F2V6MA
ada8: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada8: Command Queueing enabled
ada8: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada8: quirks=0x1<4K>
ada8: Previously was known as ad24
ada9 at ahcich3 bus 0 scbus12 target 0 lun 0
ada9: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada9: Serial Number W1F51ECL
ada9: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada9: Command Queueing enabled
ada9: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada9: quirks=0x1<4K>
ada9: Previously was known as ad26
ada10 at ahcich4 bus 0 scbus13 target 0 lun 0
ada10: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada10: Serial Number Z1F55TKE
ada10: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada10: Command Queueing enabled
ada10: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada10: quirks=0x1<4K>
ada10: Previously was known as ad28
ada11 at ahcich5 bus 0 scbus14 target 0 lun 0
ada11: <ST3000DM001-1CH166 CC29> ATA-9 SATA 3.x device
ada11: Serial Number W1F51EFC
ada11: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada11: Command Queueing enabled
ada11: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada11: quirks=0x1<4K>
ada11: Previously was known as ad30
SMP: AP CPU #7 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #5 Launched!
uhub3: 6 ports with 6 removable, self powered
(aprobe0:mvsch2:0:0:0): SETFEATURES SET TRANSFER MODE. ACB: ef 03 00 00 00 40 00 00 00 00 46 00
(aprobe0:mvsch2:0:0:0): CAM status: Unconditionally Re-queue Request
(aprobe0:mvsch2:0:0:0): Error 5, Retry was blocked
ugen3.2: <SanDisk> at usbus3
umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/2.01, addr 2> on usbus3
umass0: SCSI over Bulk-Only; quirks = 0x0100
umass0:16:0:-1: Attached to scbus16
da0 at umass-sim0 bus 0 scbus16 target 0 lun 0
da0: <SanDisk Cruzer Fit 2.01> Fixed Direct Access SCSI-6 device
da0: Serial Number 4C530301230125108365
da0: 40.000MB/s transfers
da0: 3819MB (7821312 512 byte sectors: 255H 63S/T 486C)
da0: quirks=0x2<NO_6_BYTE>
ugen3.3: <Peppercon AG> at usbus3
uhid0: <Peppercon AG Multidevice, class 0/0, rev 2.00/0.01, addr 3> on usbus3
ukbd0: <Peppercon AG Multidevice, class 0/0, rev 2.00/0.01, addr 3> on usbus3
kbd2 at ukbd0
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
(aprobe1:mvsch2:0:15:0): SOFT_RESET. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
(aprobe1:mvsch2:0:15:0): CAM status: Unconditionally Re-queue Request
(aprobe1:mvsch2:0:15:0): Error 5, Retry was blocked
(aprobe0:mvsch2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_ELI: Device ada8p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: software
GEOM_ELI: Device ada7p1.eli created.
GEOM_ELI: Device ada6p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Device ada9p1.eli created.
GEOM_ELI: Crypto: softwareHow can I tell what device it is talking about?
