Hi Guys,
after i got several errors i decided to recovery my pool from a replication backup from an external drive.
I experienced a lot of trouble while doing that and my apps are totally broken now.
Well done i should better choose another pool to migrate my apps instead of just use a replication as i know now.
BUT what i dont understand.
Why cant i reset the Application Management by deleting the ix-application dataset and unset the pool in applications?
I get still errors after deleting everything and want to start from scratch with all Apps freshly installed but it wont work either.
Where are still needed files/ services who could block this?
Why do i have now to reinstall my hole TrueNAS OS to get over this?
Isnt there not a better solution?
Greets
PS: what i also not understand is, why do i get disk write errors when acitvating apps but not while making a restore from a replication task or by zfs send. Whats the difference in the operation?
Greets
