I'm having problems connecting my UPS to FreeNAS via USB cable. The FreeNAS is able to see the UPS device, but doesn't install it.
UPS model: APC Back-UPS CS 650
OS: FreeNAS 8.0.1 Release
Settings FreeNAS:
Driver: APC Back-UPS USB USB (usbhid-ups)
Port: /dev/ugen0.2
Log:
I've been trying other ports, other drivers and also searching this forum. The log indicates that this have something to do with "nut" - whatever that might be. Obviously I am not very familiar with FreeBSD.
Also found other threads suggesting FreeNAS is having difficulties with some UPS models, is this correct? Is there any solution to my problem, or do I have to wait for another release?
Settings FreeNAS:
Port: /dev/ugen0.2
Log:
freenas: Using subdriver: APC HID 0.93 freenas: Network UPS Tools - Generic HID driver 0.34 (2.4.1) freenas: USB communication driver 0.31 freenas: Can't initialize data from HID UPS freenas: Driver failed to start (exit status=1) freenas: Network UPS Tools - UPS driver controller 2.4.1 root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut freenas: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut freenas[1642]: Executing: /usr/sbin/service nut_upsmon restart freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid). freenas: Starting nut_upsmon. freenas: UPS: ups (master) (power value 1) freenas[1642]: Executing: /usr/sbin/service nut_upslog restart upsmon[2404]: UPS [ups]: connect failed: Connection failure: Connection refused upsmon[2404]: Communications with UPS ups lost freenas: nut_upslog not running? (check /var/db/nut/upslog.pid). freenas: Starting nut_upslog. freenas: Warning: initial connect failed: Connection failure: Connection refused freenas[1642]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd upsmon[2404]: UPS [ups]: connect failed: Connection failure: Connection refused upsmon[2404]: UPS ups is unavailable
