jerryjharrison
 - Jan 15, 2014
I have a jailed owncloud installation that has been running perfectly on Freenas 11.0-U2 for several weeks.  My certbot based certificate was due to expire so I set up a cron job to call "certbot renew", as per recommendations, and it promptly renewed the certificate, and all seemed well with the world.  I have run the renewed certificates for several days without any noticeable errors.
This morning, I decided to reboot the jail. Apache is now refusing to start. In the httpe-error.log file I can see the following 2 errors:
I have tried many different options including installing openssl from Pkg, and changeing the /etc/make.conf to use the pkg version, and then deleting and re-installing Apache24. Nothing I have done changes the errors, or gets apache to start.
Any assistance would be greatly appreciated.
[Sun Jul 30 09:30:14.084723 2017] [ssl:warn] [pid 99789] AH01882: Init: this version of mod_ssl was compiled against a newer library (OpenSSL 1.0.2k-freebsd 26 Jan 2017, version currently loaded is OpenSSL 1.0.2j-freebsd 26 Sep 2016) - may result in undefined or erroneous behavior [Sun Jul 30 09:30:14.085333 2017] [ssl:emerg] [pid 99789] AH02565: Certificate and private key www.jerryharrison.net:443:0 from /usr/local/etc/letsencrypt/live/jerryharrison.net/fullchain.pem and /usr/local/etc/letsencrypt/keys/0000_key-certbot.pem do not match
