apache22 installation issue
uutzinger
I have successfully installed apache, php and AjaXplorer in the FreeNAS jail.
However when apache starts there are two kernel modules missing which can not be installed inside the jail and which are not available by default in FreeNAS (the host).
[warn] (2)No such file or directory: Failed to enable the 'httpready' Accept Filter
[warn] (2)No such file or directory: Failed to enable the 'dataready' Accept Filter
On the host (FreeNAS) in a terminal one would need to do the following:
kldload accf_http
kldload accf_data.ko
echo 'accf_http_load="YES"' >> /boot/loader.conf
echo 'accf_data_load="YES"' >> /boot/loader.conf
However I believe these modules are currently not available.
Does anyone know if its possible to deploy them without recompiling FreeNAS?
If there is question why one would want to bother about this:
Apache, php, mysql, tomcat are basic tools needed for many server applications.
FreeNAS jail and the plugins documentation explain how to create a full FreeBSD system within a jail.
On such a system one can install those packages.
Urs
paleoN
Given that they are modules you should be able to compile them in a FreeBSD 8.2 VM and just copy them to FN8.
uutzinger
Copying /boot/kernel/accf_*.ko from PC-BSD system with matching version number and bit depth works.
Thanks for suggestion.
