DarkLordSilver
 - Feb 15, 2014
Hi board
I'm just another guy with an LSI 9240i Controller. Everything was running fine during and after the setup of the NAS. This week i wanted to evacuate my data off an old Hitachi SMS100 array with failing PSU, so i went and put all the data on my FreeNAS Array. It's a small supermicro server with Intel Board and two RAIDz Pools.
4x1TB WD Green
4x2TB WD Green
Controller is said LSI 9240i-8 and everything is running in JBOD, as it was suggested by the manual.
I set up the freeNAS quite some time ago, used is rarely and never had any big issues. But since i startet to put large amounts of data to the array coming from my SMS100, there seem to be problems and issues.
So i got very ugly hangs while transferring and went to look at the console.
- Saw a lot of mfi sense errors on one specific disk
- startet to troubleshoot and learned, that:
-- my driver is wrong (shouldn't use mfi, but i wasn't given a choice when installing)
-- my controller is wrong (shouldn't use LSI9240i, but was recommend when i built the system)
-- my firmware is wrong (should use the 9218 IT Firmware)
What i already did:
- tried to evacuate from pool1 to pool2, because the error only showed up in pool1.
-> Result: now pool2 also shows the error, which seems to come above a certain filling level.
- checked said disks with the sense errors externally for SMART errors, since smartctl won't run on the BSD Box.
-> no errors on the Disk
- Updated the FreeNAS from 9.3 to 9.10 stable
-> no changes in behaviour, errors do still come
So here I am and these are my options:
Option 1: I have another RAID Controller, Adaptec 3805. Put this one in and hope FreeNAS will handle the change
Option2: Leave it as it is and scrub both pools and hope it will fix it
Option 3: Flash the LSI controller to 9218 IT and hope it will be ok then.
Option 4 Bonus: What i'm going to do anyway: Try to copy everything off the NAS to a HD before i start doing something.
What would you recommend?
4x1TB WD Green
4x2TB WD Green
What i already did:
