wakemaster
 - Mar 3, 2014
Hello All,
Been trolling the forums for a while now trying to compile a list in my head of what I think would work in my situation and pull it all together. The goal of this build is to act as a NAS, and transcoder somewhere in the future. To that end I have been looking up the hardware I likely need and settled on the following.
CPU: E3-1230v3
MOBO: SuperMicro X10SL7-F
PSU: SeaSonic SSP-450RT
HDD: 3x 1 TB WD Blacks
Case: Fractal Node 304 Black
RAM: 2x 8GB ECC compatible Samsung Sticks
I currently own the Blacks, which is why the choice. Once I get things running and tested I plan on upgrading the drives, just saves the money in the short term.
The main reason for the PSU, is to future proof a bit to allow me to use the SAS ports in the future but also because I remember reading on the forums that the suggested PSU should have a 120mm fan. The issue I am having here is looking at the Nodes layout, it appears that the fan will be blowing its hot air into the case, and directly into the HDD's. Has anyone put in this size, or this exact PSU into a Node Case and can offer thoughts on if I should look elsewhere on the PSU? I would like to stick to a gold standard PSU for the energy savings if possible. Also is using a modular PSU even feasible in this size of a case?
Thanks for the help
CPU: E3-1230v3
Thanks for the help
