Faluzure
- Oct 9, 2014
So I found a couple threads in the past on that topic above. The one that helped me the most was this one:
https://forums.freenas.org/index.ph...-1-currently-unreadable-pending-sectors.9824/
Following HHawk's instructions, I did as he instructed and performed the dd command.
REF: https://forums.freenas.org/index.ph...y-unreadable-pending-sectors.9824/#post-42966
Now... looking at the output of smartctl, it's showing the last 3 tests (2 long, 1 short) show no errors). However, Current_Pending_Sector is still showing the value of "1" and the GUI keeps spitting out the error:
1 Currently unreadable (pending) sectors.
Also, HHawk made a comment "You don't need to replace the disk if you still have extra sectors." in his thread. How can you tell if you have extra sectors?
Here is my output for reference. Do I still have bad sectors?
[root@FreeNAS] ~# smartctl -a /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N7RCLUU5
LU WWN Device Id: 5 0014ee 2b5a44047
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue May 17 11:26:25 2016 CDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40860) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 410) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 75
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13328
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 85
194 Temperature_Celsius 0x0022 121 117 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 198 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 13318 -
# 2 Extended offline Completed without error 00% 13317 -
# 3 Extended offline Completed without error 00% 13301 -
# 4 Extended offline Completed: read failure 90% 13284 4191608
# 5 Extended offline Completed: read failure 90% 13280 220324088
# 6 Short offline Aborted by host 10% 13278 -
# 7 Short offline Completed without error 00% 13246 -
# 8 Short offline Completed without error 00% 13222 -
# 9 Short offline Completed without error 00% 13198 -
#10 Short offline Completed without error 00% 13174 -
#11 Short offline Completed without error 00% 13150 -
#12 Short offline Completed without error 00% 13126 -
#13 Short offline Completed without error 00% 13102 -
#14 Short offline Completed without error 00% 13078 -
#15 Short offline Completed without error 00% 13054 -
#16 Short offline Completed without error 00% 13030 -
#17 Short offline Completed without error 00% 13006 -
#18 Short offline Completed without error 00% 12982 -
#19 Short offline Completed without error 00% 12958 -
#20 Short offline Completed without error 00% 12947 -
#21 Short offline Completed without error 00% 12910 -
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 2
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
