flmmartins
- Sep 19, 2022
I am struggling to install Nextcloud. I spend DAYS to configure it and I realized that:
1. If you add files from Samba share it doesn't synchronize with NextCloud then you need to use occ commands to sync files
2. Although I use a Dataset for data. It's very opinionated. I had to move my files to a specific location inside my dataset (dataset/nextcloud/data or smth like that) and then it works.
I wanted an app where it is flexible enough to recognize when I add a file via Samba share, I can edit and add files my phone and mounts a data volume and it's done.
Do you have recommendations for apps that can do this? Thanks
