I am running FreeNAS-9.10.2-U5.  Problem was present while running FreeNAS-9.10.2-U1 so I upgraded to U5 but that did not fix my plugins.  Plugins won't start and not sure what to do.  Here are some logs if anyone would like to help me.  Thank you!  I am running CouchPotato, SickRage, Sabnzbd and PlexMediaServer.  No plugin will start.  Any help is very appreciated!  I realize this is a long paste and I will edit it to the exact error if I can figure out what is wrong so its not so much to read.  All plugins are in the same jail and the pbis were uploaded directly to it.
Jun 12 22:37:45 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Jun 12 22:37:45 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused Jun 12 22:37:45 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused Jun 12 22:37:46 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:46 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:46 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:47 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:47 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:47 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:48 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:48 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:48 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:49 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Jun 12 22:37:49 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused Jun 12 22:37:49 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Input/output error Jun 12 22:37:50 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:50 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:50 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:51 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:51 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:51 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:52 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:52 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:52 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:53 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused Jun 12 22:37:53 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Input/output error Jun 12 22:37:53 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Input/output error Jun 12 22:37:54 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:54 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:54 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:55 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:55 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:55 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:37:56 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:56 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:56 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:37:57 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused Jun 12 22:37:57 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Input/output error Jun 12 22:37:57 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Input/output error Jun 12 22:37:59 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:59 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:37:59 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:00 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:00 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:00 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:01 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:01 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:01 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:02 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Jun 12 22:38:02 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused Jun 12 22:38:02 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Input/output error Jun 12 22:38:03 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:03 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:03 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:04 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:04 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:04 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:05 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:05 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:05 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:38:06 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused Jun 12 22:38:06 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused Jun 12 22:38:06 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused Jun 12 22:38:07 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:07 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:07 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:38:08 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:08 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:08 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:38:09 freenas syslog-ng[81394]: syslog-ng shutting down; version='3.6.4' Jun 12 22:57:22 freenas syslog-ng[1344]: syslog-ng starting up; version='3.6.4' ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jun 12 22:57:22 freenas random: <Software, Yarrow> initialized Jun 12 22:57:22 freenas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. Jun 12 22:57:22 freenas ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 64/32 (20160527/tbfadt-650) Jun 12 22:57:22 freenas ioapic0 <Version 2.1> irqs 0-23 on motherboard Jun 12 22:57:22 freenas kbd1 at kbdmux0 Jun 12 22:57:22 freenas aesni0: No AESNI support. Jun 12 22:57:22 freenas padlock0: No ACE support. Jun 12 22:57:22 freenas cryptosoft0: <software crypto> on motherboard Jun 12 22:57:22 freenas acpi0: <HP ProLiant> on motherboard Jun 12 22:57:22 freenas acpi0: Power Button (fixed) Jun 12 22:57:22 freenas cpu0: <ACPI CPU> on acpi0 Jun 12 22:57:22 freenas cpu1: <ACPI CPU> on acpi0 Jun 12 22:57:22 freenas attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 Jun 12 22:57:22 freenas Timecounter "i8254" frequency 1193182 Hz quality 0 Jun 12 22:57:22 freenas Event timer "i8254" frequency 1193182 Hz quality 100 Jun 12 22:57:22 freenas atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 Jun 12 22:57:22 freenas Event timer "RTC" frequency 32768 Hz quality 0 Jun 12 22:57:22 freenas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Jun 12 22:57:22 freenas Timecounter "HPET" frequency 14318180 Hz quality 950 Jun 12 22:57:22 freenas Event timer "HPET" frequency 14318180 Hz quality 550 Jun 12 22:57:22 freenas Event timer "HPET1" frequency 14318180 Hz quality 450 Jun 12 22:57:22 freenas Timecounter "ACPI-safe" frequency 3579545 Hz quality 850 Jun 12 22:57:22 freenas acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0 Jun 12 22:57:22 freenas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 Jun 12 22:57:22 freenas pci0: <ACPI PCI bus> on pcib0 Jun 12 22:57:22 freenas pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0 Jun 12 22:57:22 freenas pci1: <ACPI PCI bus> on pcib1 Jun 12 22:57:22 freenas vgapci0: <VGA-compatible display> port 0xe000-0xe0ff mem 0xf0000000-0xf7ffffff,0xfe8f0000-0xfe8fffff,0xfe700000-0xfe7fffff irq 18 at device 5.0 on pci1 Jun 12 22:57:22 freenas vgapci0: Boot video device Jun 12 22:57:22 freenas pcib2: <ACPI PCI-PCI bridge> irq 18 at device 6.0 on pci0 Jun 12 22:57:22 freenas pci2: <ACPI PCI bus> on pcib2 Jun 12 22:57:22 freenas bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f0000-0xfe9fffff irq 18 at device 0.0 on pci2 Jun 12 22:57:22 freenas bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E Jun 12 22:57:22 freenas miibus0: <MII bus> on bge0 Jun 12 22:57:22 freenas brgphy0: <BCM5784 10/100/1000baseT PHY> PHY 1 on miibus0 Jun 12 22:57:22 freenas brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow Jun 12 22:57:22 freenas bge0: Using defaults for TSO: 65518/35/2048 Jun 12 22:57:22 freenas bge0: Ethernet address: 00:9c:02:a0:44:34 Jun 12 22:57:22 freenas ahci0: <AMD SB7x0/SB8x0/SB9x0 AHCI SATA controller> port 0xd000-0xd007,0xc000-0xc003,0xb000-0xb007,0xa000-0xa003,0x9000-0x900f mem 0xfe6ffc00-0xfe6fffff irq 19 at device 17.0 on pci0 Jun 12 22:57:22 freenas ahci0: AHCI v1.20 with 4 3Gbps ports, Port Multiplier supported Jun 12 22:57:22 freenas ahci0: quirks=0x22000<ATI_PMP_BUG,1MSI> Jun 12 22:57:22 freenas ahcich0: <AHCI channel> at channel 0 on ahci0 Jun 12 22:57:22 freenas ahcich1: <AHCI channel> at channel 1 on ahci0 Jun 12 22:57:22 freenas ahcich2: <AHCI channel> at channel 2 on ahci0 Jun 12 22:57:22 freenas ahcich3: <AHCI channel> at channel 3 on ahci0 Jun 12 22:57:22 freenas ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fe000-0xfe6fefff irq 18 at device 18.0 on pci0 Jun 12 22:57:22 freenas usbus0 on ohci0 Jun 12 22:57:22 freenas ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff800-0xfe6ff8ff irq 17 at device 18.2 on pci0 Jun 12 22:57:22 freenas usbus1: EHCI version 1.0 Jun 12 22:57:22 freenas usbus1 on ehci0 Jun 12 22:57:22 freenas ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fd000-0xfe6fdfff irq 18 at device 19.0 on pci0 Jun 12 22:57:22 freenas usbus2 on ohci1 Jun 12 22:57:22 freenas ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff400-0xfe6ff4ff irq 17 at device 19.2 on pci0 Jun 12 22:57:22 freenas usbus3: EHCI version 1.0 Jun 12 22:57:22 freenas usbus3 on ehci1 Jun 12 22:57:22 freenas atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0 Jun 12 22:57:22 freenas ata0: <ATA channel> at channel 0 on atapci0 Jun 12 22:57:22 freenas ata1: <ATA channel> at channel 1 on atapci0 Jun 12 22:57:22 freenas isab0: <PCI-ISA bridge> at device 20.3 on pci0 Jun 12 22:57:22 freenas isa0: <ISA bus> on isab0 Jun 12 22:57:22 freenas pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0 Jun 12 22:57:22 freenas pci3: <ACPI PCI bus> on pcib3 Jun 12 22:57:22 freenas ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe6fc000-0xfe6fcfff irq 18 at device 22.0 on pci0 Jun 12 22:57:22 freenas usbus4 on ohci2 Jun 12 22:57:22 freenas ehci2: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe6ff000-0xfe6ff0ff irq 17 at device 22.2 on pci0 Jun 12 22:57:22 freenas usbus5: EHCI version 1.0 Jun 12 22:57:22 freenas usbus5 on ehci2 Jun 12 22:57:22 freenas amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb4 Jun 12 22:57:22 freenas acpi_button0: <Power Button> on acpi0 Jun 12 22:57:22 freenas amdsbwd0: <AMD SB8xx/SB9xx/Axx Watchdog Timer> at iomem 0xfec000f0-0xfec000f3,0xfec000f4-0xfec000f7 on isa0 Jun 12 22:57:22 freenas sc0: <System console> at flags 0x100 on isa0 Jun 12 22:57:22 freenas sc0: VGA <16 virtual consoles, flags=0x300> Jun 12 22:57:22 freenas vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Jun 12 22:57:22 freenas hwpstate0: <Cool`n'Quiet 2.0> on cpu0 Jun 12 22:57:22 freenas random: unblocking device. Jun 12 22:57:22 freenas usbus0: 12Mbps Full Speed USB v1.0 Jun 12 22:57:22 freenas usbus1: 480Mbps High Speed USB v2.0 Jun 12 22:57:22 freenas usbus2: 12Mbps Full Speed USB v1.0 Jun 12 22:57:22 freenas usbus3: 480Mbps High Speed USB v2.0 Jun 12 22:57:22 freenas usbus4: 12Mbps Full Speed USB v1.0 Jun 12 22:57:22 freenas usbus5: 480Mbps High Speed USB v2.0 Jun 12 22:57:22 freenas ZFS filesystem version: 5 Jun 12 22:57:22 freenas ZFS storage pool version: features support (5000) Jun 12 22:57:22 freenas Timecounters tick every 1.000 msec Jun 12 22:57:22 freenas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Jun 12 22:57:22 freenas ugen5.1: <ATI> at usbus5 Jun 12 22:57:22 freenas uhub0: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5 Jun 12 22:57:22 freenas ugen4.1: <ATI> at usbus4 Jun 12 22:57:22 freenas uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4 Jun 12 22:57:22 freenas ugen3.1: <ATI> at usbus3 Jun 12 22:57:22 freenas uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3 Jun 12 22:57:22 freenas ugen2.1: <ATI> at usbus2 Jun 12 22:57:22 freenas uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2 Jun 12 22:57:22 freenas ugen1.1: <ATI> at usbus1 Jun 12 22:57:22 freenas uhub4: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 Jun 12 22:57:22 freenas ugen0.1: <ATI> at usbus0 Jun 12 22:57:22 freenas uhub5: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 Jun 12 22:57:22 freenas uhub1: 4 ports with 4 removable, self powered Jun 12 22:57:22 freenas uhub3: 5 ports with 5 removable, self powered Jun 12 22:57:22 freenas uhub5: 5 ports with 5 removable, self powered Jun 12 22:57:22 freenas uhub0: 4 ports with 4 removable, self powered Jun 12 22:57:22 freenas uhub2: 5 ports with 5 removable, self powered Jun 12 22:57:22 freenas uhub4: 5 ports with 5 removable, self powered Jun 12 22:57:22 freenas ugen0.2: <vendor 0x0b38> at usbus0 Jun 12 22:57:22 freenas ukbd0: <vendor 0x0b38 product 0x0010, class 0/0, rev 1.10/1.02, addr 2> on usbus0 Jun 12 22:57:22 freenas kbd0 at ukbd0 Jun 12 22:57:22 freenas ugen3.2: <SanDisk> at usbus3 Jun 12 22:57:22 freenas umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.10/1.00, addr 2> on usbus3 Jun 12 22:57:22 freenas umass0: SCSI over Bulk-Only; quirks = 0xc100 Jun 12 22:57:22 freenas umass0:7:0:-1: Attached to scbus7 Jun 12 22:57:22 freenas ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 Jun 12 22:57:22 freenas ada0: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device Jun 12 22:57:22 freenas ada0: Serial Number WD-WMC4N0793924 Jun 12 22:57:22 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Jun 12 22:57:22 freenas ada0: Command Queueing enabled Jun 12 22:57:22 freenas ada0: 2861588MB (5860533168 512 byte sectors) Jun 12 22:57:22 freenas ada0: quirks=0x1<4K> Jun 12 22:57:22 freenas ada0: Previously was known as ad4 Jun 12 22:57:22 freenas ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 Jun 12 22:57:22 freenas ada1: <WDC WD30EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Jun 12 22:57:22 freenas ada1: Serial Number WD-WCC4N3HC8S3T Jun 12 22:57:22 freenas ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Jun 12 22:57:22 freenas ada1: Command Queueing enabled Jun 12 22:57:22 freenas ada1: 2861588MB (5860533168 512 byte sectors) Jun 12 22:57:22 freenas ada1: quirks=0x1<4K> Jun 12 22:57:22 freenas ada1: Previously was known as ad6 Jun 12 22:57:22 freenas ada2 at ahcich2 bus 0 scbus2 target 0 lun 0 Jun 12 22:57:22 freenas ada2: <WDC WD30EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Jun 12 22:57:22 freenas ada2: Serial Number WD-WCC4N6ZDP7R6 Jun 12 22:57:22 freenas ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Jun 12 22:57:22 freenas ada2: Command Queueing enabled Jun 12 22:57:22 freenas ada2: 2861588MB (5860533168 512 byte sectors) Jun 12 22:57:22 freenas ada2: quirks=0x1<4K> Jun 12 22:57:22 freenas ada2: Previously was known as ad8 Jun 12 22:57:22 freenas ada3 at ahcich3 bus 0 scbus3 target 0 lun 0 Jun 12 22:57:22 freenas ada3: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device Jun 12 22:57:22 freenas ada3: Serial Number WD-WMC4N2934444 Jun 12 22:57:22 freenas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Jun 12 22:57:22 freenas ada3: Command Queueing enabled Jun 12 22:57:22 freenas ada3: 2861588MB (5860533168 512 byte sectors) Jun 12 22:57:22 freenas ada3: quirks=0x1<4K> Jun 12 22:57:22 freenas ada3: Previously was known as ad10 Jun 12 22:57:22 freenas da0 at umass-sim0 bus 0 scbus7 target 0 lun 0 Jun 12 22:57:22 freenas da0: <SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device Jun 12 22:57:22 freenas da0: Serial Number 4C530001050809110312 Jun 12 22:57:22 freenas da0: 40.000MB/s transfers Jun 12 22:57:22 freenas da0: 30528MB (62521344 512 byte sectors) Jun 12 22:57:22 freenas da0: quirks=0x2<NO_6_BYTE> Jun 12 22:57:22 freenas SMP: AP CPU #1 Launched! Jun 12 22:57:22 freenas Timecounter "TSC" frequency 1497537535 Hz quality 800 Jun 12 22:57:22 freenas Trying to mount root from zfs:freenas-boot/ROOT/default-20170613-024846 []... Jun 12 22:57:22 freenas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Jun 12 22:57:22 freenas ipmi0: <IPMI System Interface> on isa0 Jun 12 22:57:22 freenas ipmi0: KCS mode found at mem 0x0 alignment 0x1 on isa Jun 12 22:57:22 freenas ipmi0: couldn't configure I/O resource Jun 12 22:57:22 freenas device_attach: ipmi0 attach returned 6 Jun 12 22:57:22 freenas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> K8/4/48/0x1ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA> Jun 12 22:57:22 freenas kernel: bge0: link state changed to DOWN Jun 12 22:57:22 freenas kernel: bge0: link state changed to DOWN Jun 12 22:57:22 freenas uhid0: <vendor 0x0b38 product 0x0010, class 0/0, rev 1.10/1.02, addr 2> on usbus0 Jun 12 22:57:22 freenas kernel: bge0: link state changed to UP Jun 12 22:57:22 freenas kernel: bge0: link state changed to UP Jun 12 22:57:24 freenas GEOM_ELI: Device ada0p1.eli created. Jun 12 22:57:24 freenas GEOM_ELI: Encryption: AES-XTS 128 Jun 12 22:57:24 freenas GEOM_ELI: Crypto: software Jun 12 22:57:24 freenas GEOM_ELI: Device ada1p1.eli created. Jun 12 22:57:24 freenas GEOM_ELI: Encryption: AES-XTS 128 Jun 12 22:57:24 freenas GEOM_ELI: Crypto: software Jun 12 22:57:24 freenas GEOM_ELI: Device ada2p1.eli created. Jun 12 22:57:24 freenas GEOM_ELI: Encryption: AES-XTS 128 Jun 12 22:57:24 freenas GEOM_ELI: Crypto: software Jun 12 22:57:24 freenas GEOM_ELI: Device ada3p1.eli created. Jun 12 22:57:24 freenas GEOM_ELI: Encryption: AES-XTS 128 Jun 12 22:57:24 freenas GEOM_ELI: Crypto: software Jun 12 22:57:25 freenas ntpd[1764]: ntpd 4.2.8p9-a (1): Starting Jun 12 22:57:27 freenas proftpd[1915]: 127.0.0.1 - ProFTPD 1.3.5a (maint) (built Thu Jun 8 2017 20:12:35 UTC) standalone mode STARTUP Jun 12 22:57:30 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Jun 12 22:57:30 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd Jun 12 22:57:31 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Jun 12 22:57:32 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Jun 12 22:57:33 freenas smbd: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:35 Err:-1 Errno:2 No such file or directory Jun 12 22:57:41 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Jun 12 22:57:41 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Jun 12 22:57:42 freenas alert.py: [freenasOS.Update:1572] Cached sequence, 1e055f208642fd566b9f569d31cd01a9, does not match system sequence, 3c693eb3ffa689371074d2ddaab93d59 Jun 12 22:57:42 freenas alert.py: [freenasOS.Update:1114] Cached sequence does not match system sequence Jun 12 22:57:51 freenas bridge0: Ethernet address: 02:6e:e0:51:be:00 Jun 12 22:57:51 freenas kernel: bridge0: link state changed to UP Jun 12 22:57:51 freenas kernel: bridge0: link state changed to UP Jun 12 22:57:51 freenas kernel: bge0: promiscuous mode enabled Jun 12 22:57:51 freenas epair0a: Ethernet address: 02:ff:60:00:04:0a Jun 12 22:57:51 freenas epair0b: Ethernet address: 02:ff:b0:00:05:0b Jun 12 22:57:51 freenas kernel: epair0a: link state changed to UP Jun 12 22:57:51 freenas kernel: epair0a: link state changed to UP Jun 12 22:57:51 freenas kernel: epair0b: link state changed to UP Jun 12 22:57:51 freenas kernel: epair0b: link state changed to UP Jun 12 22:57:51 freenas kernel: epair0a: promiscuous mode enabled Jun 12 22:57:51 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b Jun 12 22:57:51 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b Jun 12 22:58:00 freenas epair1a: Ethernet address: 02:ff:60:00:05:0a Jun 12 22:58:00 freenas epair1b: Ethernet address: 02:ff:b0:00:06:0b Jun 12 22:58:00 freenas kernel: epair1a: link state changed to UP Jun 12 22:58:00 freenas kernel: epair1a: link state changed to UP Jun 12 22:58:00 freenas kernel: epair1b: link state changed to UP Jun 12 22:58:00 freenas kernel: epair1b: link state changed to UP Jun 12 22:58:00 freenas kernel: epair1a: promiscuous mode enabled Jun 12 22:58:00 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair1b Jun 12 22:58:00 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair1b Jun 12 22:58:11 freenas epair2a: Ethernet address: 02:ff:60:00:06:0a Jun 12 22:58:11 freenas epair2b: Ethernet address: 02:ff:b0:00:07:0b Jun 12 22:58:11 freenas kernel: epair2a: link state changed to UP Jun 12 22:58:11 freenas kernel: epair2a: link state changed to UP Jun 12 22:58:11 freenas kernel: epair2b: link state changed to UP Jun 12 22:58:11 freenas kernel: epair2b: link state changed to UP Jun 12 22:58:11 freenas kernel: epair2a: promiscuous mode enabled Jun 12 22:58:11 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair2b Jun 12 22:58:11 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair2b Jun 12 22:58:25 freenas epair3a: Ethernet address: 02:ff:60:00:07:0a Jun 12 22:58:25 freenas epair3b: Ethernet address: 02:ff:b0:00:08:0b Jun 12 22:58:25 freenas kernel: epair3a: link state changed to UP Jun 12 22:58:25 freenas kernel: epair3a: link state changed to UP Jun 12 22:58:25 freenas kernel: epair3b: link state changed to UP Jun 12 22:58:25 freenas kernel: epair3b: link state changed to UP Jun 12 22:58:25 freenas kernel: epair3a: promiscuous mode enabled Jun 12 22:58:25 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair3b Jun 12 22:58:25 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair3b
