All deployed apps suddenly gone... (TrueNAS-SCALE-22.12.3.2)
georgelza
Hi there
Slightly worried...
Had
(TrueCharts)
Plex, QBittorent -> Running
Unifi Controller -Running
MetalLB
Docker: InfluxDB - Problems, authorisation errors, it was pointing to /mnt/Apps/indluxdb (dataset)
Docker: Speedtest -> Running/working
deployed
As per Tom's YouTube video last night he advises to to set a dataset that will host data for a app to the ACL apps profile.
Then continue to advise to disable Host Path Safety checks.... I did...
when I now clicked on Apps, they all gone...
don't want to touch much else atm, hoping there is logs and there is a way of getting my apps back without having to reconfigure everything.
I've just now gotten the attached alert raised.
G
georgelza
NOTE: on recommendation of another user on the forum I tried a well known microsoft fix... reboot the NAS...
worked, all apps back to visible in the apps section, so it seems there is a bug some where in hopefully the UI only.
happy to provide logs if it can help development.
G
georgelza
went looking,
was able to reproduce.
Disable Host Path validation,
re-enable HPV.
Apps gone...
georgelza
NOTE: actually just realised, this is not UI only,
As when the apps disappeared from the Apps section... I also could not access Plex service, the restart of the NAS was required to have the Apps show the deployed Apps and as when it is now showing, I can access Plex again.
G
