after upgrade from 8.3 to 9.2 => periodic reboot (crash?)
I don't have any good recommendations. My first guess is some kind of hardware failure, but narrowing down the exact hardware is going to be difficult. You might just have to do trial and error.
I do find it very odd that you are using the x64 version of FreeNAS but don't have high RAM utilization. Do you have any tunables or sysctls set in the WebGUI? Did you enable the autotune(hint: you shouldn't use autotune for your situation)?
Dennis.kulmosen
I would start with a simple reseating of the RAM modules. I had similar issue with a 128GB system only utilizing about 24GB. Reseat of RAM solved my issue. Otherwise try the memtest.
galaxsat
Just an update- my problem was apparently memory. I replaced the 2x4GB sticks and up for 15 days without a hiccup. Thanks for the nudge in the right direction!
kamuzon
Hello.
Now I use FreeNAS-9.3-STABLE-201412142326
MB: GigaByte GA-MA78GPM-DS2H (RS780-SB700)
CPU: AMD Phenom(tm) 9750 Quad-Core Processor (2411.03-MHz K8-class CPU)
AddOn Card 1: JMicron JMB363 UDMA133 controller
AddOn Card 2: Promise Technology, Inc. SATA 300 TX2plus
8GB of RAM
Debug in attach.
I did RAM test 341 pass - no error. (I forgot about this server, so it tested and tested about 1008 hours ;))
But system still reboots under load. :(
What should I do? Change JMicron controller?
dmesg:
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p5 #0 3b4abc3: Sun Dec 14 12:56:11 PST 2014
    root@build3.ixsystems.com:/tank/home/jkh/build/93/FN/objs/os-base/amd64/fusion/jkh/93/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
  Origin = "AuthenticAMD"  Id = 0x100f23  Family = 0x10  Model = 0x2  Stepping = 3
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x802009<SSE3,MON,CX16,POPCNT>
  AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
  AMD Features2=0x7ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS>
  TSC: P-state invariant
real memory  = 9261023232 (8832 MB)
avail memory = 8099946496 (7724 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <GBT    GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
cpu2 (AP): APIC ID:  2
cpu3 (AP): APIC ID:  3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.1> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <GBT GBTUACPI> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, cfde0000 (3) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 450
Event timer "HPET2" frequency 14318180 Hz quality 450
atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xee00-0xeeff mem 0xd8000000-0xdfffffff,0xfdde0000-0xfddeffff,0xfdc00000-0xfdcfffff irq 18 at device 5.0 on pci1
vgapci0: Boot video device
pci1: <multimedia, HDA> at device 5.1 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib2
atapci0: <JMicron JMB363 UDMA133 controller> port 0xdf00-0xdf07,0xde00-0xde03,0xdd00-0xdd07,0xdc00-0xdc03,0xdb00-0xdb0f mem 0xfdbfe000-0xfdbfffff irq 18 at device 0.0 on pci2
ahci0: <JMicron JMB363 AHCI SATA controller> at channel -1 on atapci0
ahci0: AHCI v1.00 with 2 3Gbps ports, Port Multiplier supported
ahci0: quirks=0x1<NOFORCE>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ata2: <ATA channel> at channel 0 on atapci0
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 10.0 on pci0
pci3: <ACPI PCI bus> on pcib3
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xce00-0xceff mem 0xfdeff000-0xfdefffff,0xfdee0000-0xfdeeffff irq 18 at device 0.0 on pci3
re0: Using 1 MSI-X message
re0: Chip rev. 0x3c000000
re0: MAC rev. 0x00200000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 00:1f:d0:51:b7:67
ahci1: <AMD SB7x0/SB8x0/SB9x0 AHCI SATA controller> port 0xff00-0xff07,0xfe00-0xfe03,0xfd00-0xfd07,0xfc00-0xfc03,0xfb00-0xfb0f mem 0xfe02f000-0xfe02f3ff irq 22 at device 17.0 on pci0
ahci1: AHCI v1.10 with 4 3Gbps ports, Port Multiplier supported
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02e000-0xfe02efff irq 16 at device 18.0 on pci0
usbus0 on ohci0
ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02d000-0xfe02dfff irq 16 at device 18.1 on pci0
usbus1 on ohci1
ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe02c000-0xfe02c0ff irq 17 at device 18.2 on pci0
ehci0: AMD SB600/700 quirk applied
usbus2: EHCI version 1.0
usbus2 on ehci0
ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02b000-0xfe02bfff irq 18 at device 19.0 on pci0
usbus3 on ohci2
ohci3: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe02a000-0xfe02afff irq 18 at device 19.1 on pci0
usbus4 on ohci3
ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe029000-0xfe0290ff irq 19 at device 19.2 on pci0
ehci1: AMD SB600/700 quirk applied
usbus5: EHCI version 1.0
usbus5 on ehci1
atapci1: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfa00-0xfa0f at device 20.1 on pci0
ata0: <ATA channel> at channel 0 on atapci1
ata1: <ATA channel> at channel 1 on atapci1
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib4: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci4: <ACPI PCI bus> on pcib4
atapci2: <Promise PDC40775 SATA300 controller> port 0xbf00-0xbf7f,0xbc00-0xbcff mem 0xfdaff000-0xfdafffff,0xfdac0000-0xfdadffff irq 20 at device 6.0 on pci4
ata3: <ATA channel> at channel 0 on atapci2
ata4: <ATA channel> at channel 1 on atapci2
ata5: <ATA channel> at channel 2 on atapci2
ohci4: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe028000-0xfe028fff irq 18 at device 20.5 on pci0
usbus6 on ohci4
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb4
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
orm0: <ISA Option ROMs> at iomem 0xd0000-0xd4fff,0xd5000-0xd7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe0002f50080 with IPv6 initialized (100409)
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
usbus6: 12Mbps Full Speed USB v1.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
uhub6: 2 ports with 2 removable, self powered
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
uhub3: 3 ports with 3 removable, self powered
uhub4: 3 ports with 3 removable, self powered
(aprobe0:ahcich2:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
(aprobe0:ahcich2:0:15:0): CAM status: Command timeout
(aprobe0:ahcich2:0:15:0): Error 5, Retries exhausted
(aprobe1:ahcich3:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
(aprobe1:ahcich3:0:15:0): CAM status: Command timeout
(aprobe1:ahcich3:0:15:0): Error 5, Retries exhausted
(aprobe2:ahcich4:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
(aprobe2:ahcich4:0:15:0): CAM status: Command timeout
(aprobe2:ahcich4:0:15:0): Error 5, Retries exhausted
(aprobe3:ahcich5:0:15:0): NOP. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
(aprobe3:ahcich5:0:15:0): CAM status: Command timeout
(aprobe3:ahcich5:0:15:0): Error 5, Retries exhausted
ata3: SIGNATURE: 00000101
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <ST1000VX000-1CU162 CV23> ATA-8 SATA 3.x device
ada0: Serial Number Z1D8GVJ8
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <ST1000VX000-1CU162 CV23> ATA-8 SATA 3.x device
ada1: Serial Number Z1D8MDBR
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus3 target 0 lun 0
ada2: <ST1000NC001-1DY162 CN02> ATA-8 SATA 3.x device
ada2: Serial Number Z1D8HTWC
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad10
ada3 at ahcich3 bus 0 scbus4 target 0 lun 0
ada3: <ST31000528AS CC44> ATA-8 SATA 2.x device
ada3: Serial Number 6VP0PH3D
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 953865MB (1953516911 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad12
ada4 at ahcich4 bus 0 scbus5 target 0 lun 0
ada4: <ST31000528AS CC44> ATA-8 SATA 2.x device
ada4: Serial Number 6VP0QW8F
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada4: Previously was known as ad14
ada5 at ahcich5 bus 0 scbus6 target 0 lun 0
ada5: <ST1000VX000-1CU162 CV22> ATA-8 SATA 3.x device
ada5: Serial Number Z1D45RZQ
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada5: Previously was known as ad16
ada6 at ata1 bus 0 scbus8 target 0 lun 0
ada6: <ST1000DM003-1ER162 CC43> ATA-9 SATA 3.x device
ada6: Serial Number Z4Y1B6SA
ada6: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
ada6: 953865MB (1953516911 512 byte sectors: 16H 63S/T 16383C)
ada6: quirks=0x1<4K>
ada6: Previously was known as ad2
ada7 at ata3 bus 0 scbus9 target 0 lun 0
ada7: <ST1000DM003-1ER162 CC43> ATA-9 SATA 3.x device
ada7: Serial Number Z4Y1B7B8
ada7: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada7: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada7: quirks=0x1<4K>
ada7: Previously was known as ad18
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1205517023 Hz quality 800
uhub2: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
Root mount waiting for: usbus2
ugen2.2: <JetFlash> at usbus2
umass0: <JetFlash Mass Storage Device, class 0/0, rev 2.00/1.00, addr 2> on usbus2
umass0:  SCSI over Bulk-Only; quirks = 0x4000
umass0:13:0:-1: Attached to scbus13
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201412142326 []...
da0 at umass-sim0 bus 0 scbus13 target 0 lun 0
da0: <JetFlash Transcend 4GB 8.01> Removable Direct Access SCSI-2 device
da0: Serial Number DU6O355N
da0: 40.000MB/s transfers
da0: 3818MB (7821300 512 byte sectors: 255H 63S/T 486C)
da0: quirks=0x12<NO_6_BYTE,NO_RC16>
cd0 at umass-sim0 bus 0 scbus13 target 0 lun 1
cd0: <Generic AutoRun Disk 8.00> Removable CD-ROM SCSI-2 device
cd0: Serial Number DU6O355N
cd0: 40.000MB/s transfers
cd0: cd present [22540 x 512 byte records]
cd0: quirks=0x10<10_BYTE_ONLY>
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: software
GEOM_ELI: Device ada6p1.eli created.
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
GEOM_ELI: Device ada7p1.eli created.
nfsd: can't register svc name
vboxdrv: fAsync=0 offMin=0x520 offMax=0x2300
# pciconf -lv
hostb0@pci0:0:0:0:      class=0x060000 card=0x96001022 chip=0x96001022 rev=0x00 hdr=0x00
    vendor     = 'Advanced Micro Devices [AMD]'
    device     = 'RS780 Host Bridge'
    class      = bridge
    subclass   = HOST-PCI
pcib1@pci0:0:1:0:       class=0x060400 card=0x96021022 chip=0x96021022 rev=0x00 hdr=0x01
    device     = 'RS780/RS880 PCI to PCI bridge (int gfx)'
    class      = bridge
    subclass   = PCI-PCI
pcib2@pci0:0:2:0:       class=0x060400 card=0x96001022 chip=0x96031022 rev=0x00 hdr=0x01
    device     = 'RS780 PCI to PCI bridge (ext gfx port 0)'
    class      = bridge
    subclass   = PCI-PCI
pcib3@pci0:0:10:0:      class=0x060400 card=0x96001022 chip=0x96091022 rev=0x00 hdr=0x01
    device     = 'RS780/RS880 PCI to PCI bridge (PCIE port 5)'
    class      = bridge
    subclass   = PCI-PCI
ahci1@pci0:0:17:0:      class=0x01018f card=0xb0021458 chip=0x43901002 rev=0x00 hdr=0x00
    vendor     = 'ATI Technologies Inc'
    device     = 'SB7x0/SB8x0/SB9x0 SATA Controller [IDE mode]'
    class      = mass storage
    subclass   = ATA
ohci0@pci0:0:18:0:      class=0x0c0310 card=0x50041458 chip=0x43971002 rev=0x00 hdr=0x00
    device     = 'SB7x0/SB8x0/SB9x0 USB OHCI0 Controller'
    class      = serial bus
    subclass   = USB
ohci1@pci0:0:18:1:      class=0x0c0310 card=0x50041458 chip=0x43981002 rev=0x00 hdr=0x00
    device     = 'SB7x0 USB OHCI1 Controller'
    class      = serial bus
    subclass   = USB
ehci0@pci0:0:18:2:      class=0x0c0320 card=0x50041458 chip=0x43961002 rev=0x00 hdr=0x00
    device     = 'SB7x0/SB8x0/SB9x0 USB EHCI Controller'
    class      = serial bus
    subclass   = USB
ohci2@pci0:0:19:0:      class=0x0c0310 card=0x50041458 chip=0x43971002 rev=0x00 hdr=0x00
    class      = serial bus
    subclass   = USB
ohci3@pci0:0:19:1:      class=0x0c0310 card=0x50041458 chip=0x43981002 rev=0x00 hdr=0x00
    class      = serial bus
    subclass   = USB
ehci1@pci0:0:19:2:      class=0x0c0320 card=0x50041458 chip=0x43961002 rev=0x00 hdr=0x00
    class      = serial bus
    subclass   = USB
none0@pci0:0:20:0:      class=0x0c0500 card=0x43851458 chip=0x43851002 rev=0x3a hdr=0x00
    device     = 'SBx00 SMBus Controller'
    class      = serial bus
    subclass   = SMBus
atapci1@pci0:0:20:1:    class=0x01018a card=0x50021458 chip=0x439c1002 rev=0x00 hdr=0x00
    device     = 'SB7x0/SB8x0/SB9x0 IDE Controller'
    subclass   = ATA
isab0@pci0:0:20:3:      class=0x060100 card=0x439d1002 chip=0x439d1002 rev=0x00 hdr=0x00
    device     = 'SB7x0/SB8x0/SB9x0 LPC host controller'
    class      = bridge
    subclass   = PCI-ISA
pcib4@pci0:0:20:4:      class=0x060401 card=0x00000000 chip=0x43841002 rev=0x00 hdr=0x01
    device     = 'SBx00 PCI to PCI Bridge'
    class      = bridge
    subclass   = PCI-PCI
ohci4@pci0:0:20:5:      class=0x0c0310 card=0x50041458 chip=0x43991002 rev=0x00 hdr=0x00
    device     = 'SB7x0/SB8x0/SB9x0 USB OHCI2 Controller'
    class      = serial bus
    subclass   = USB
hostb1@pci0:0:24:0:     class=0x060000 card=0x00000000 chip=0x12001022 rev=0x00 hdr=0x00
    device     = 'Family 10h Processor HyperTransport Configuration'
    class      = bridge
    subclass   = HOST-PCI
hostb2@pci0:0:24:1:     class=0x060000 card=0x00000000 chip=0x12011022 rev=0x00 hdr=0x00
    device     = 'Family 10h Processor Address Map'
    class      = bridge
    subclass   = HOST-PCI
hostb3@pci0:0:24:2:     class=0x060000 card=0x00000000 chip=0x12021022 rev=0x00 hdr=0x00
    device     = 'Family 10h Processor DRAM Controller'
    class      = bridge
    subclass   = HOST-PCI
hostb4@pci0:0:24:3:     class=0x060000 card=0x00000000 chip=0x12031022 rev=0x00 hdr=0x00
    device     = 'Family 10h Processor Miscellaneous Control'
    class      = bridge
    subclass   = HOST-PCI
hostb5@pci0:0:24:4:     class=0x060000 card=0x00000000 chip=0x12041022 rev=0x00 hdr=0x00
    device     = 'Family 10h Processor Link Control'
    class      = bridge
    subclass   = HOST-PCI
vgapci0@pci0:1:5:0:     class=0x030000 card=0xd0001458 chip=0x96101002 rev=0x00 hdr=0x00
    device     = 'Radeon HD 3200 Graphics'
    class      = display
    subclass   = VGA
none1@pci0:1:5:1:       class=0x040300 card=0x960f1002 chip=0x960f1002 rev=0x00 hdr=0x00
    device     = 'RS780 Azalia controller'
    class      = multimedia
    subclass   = HDA
atapci0@pci0:2:0:0:     class=0x010601 card=0x2363197b chip=0x2363197b rev=0x03 hdr=0x00
    vendor     = 'JMicron Technology Corp.'
    device     = 'JMB362/JMB363 Serial ATA Controller'
    subclass   = SATA
re0@pci0:3:0:0: class=0x020000 card=0xe0001458 chip=0x816810ec rev=0x02 hdr=0x00
    vendor     = 'Realtek Semiconductor Co., Ltd.'
    device     = 'RTL8111/8168B PCI Express Gigabit Ethernet controller'
    class      = network
    subclass   = ethernet
atapci2@pci0:4:6:0:     class=0x018000 card=0x3d73105a chip=0x3d73105a rev=0x02 hdr=0x00
    vendor     = 'Promise Technology, Inc.'
    device     = 'PDC40775 (SATA 300 TX2plus)'
  • debug-freenas117-20141216050836.tgz
kamuzon
Maybe it helps
            input        (Total)           output
   packets  errs idrops      bytes    packets  errs      bytes colls
       550     0     0      53594       1056     0      83378     0
       517     0     0      49083       1023     0      79450     0
       522     0     0      49672       1040     0      80562     0
      6864     0     0    9587189       7382     0     501754     0
     16161     0     0   23539595      16679     0    1120071     0
     19797     0     0   29022196      20301     0    1360761     0
     19374     0     0   28397628      19827     0    1329161     0
     16423     0     0   24063367      16773     0    1123286     0
     22494     0     0   33270351      22787     0    1523414     0
     37286     0     0   55461494      37600     0    2508542     0
     38544     0     0   57368338      38871     0    2593513     0
     38876     0     0   57836801      39194     0    2616474     0
     40916     0     0   60902312      41282     0    2753907     0
      2533     0     0    3751125       2563     0     171356     0
         4     0     0        254          2     0        244     0
       398     0     0     560204        388     0      28521     0
     47615     0     0   70887025      48039     0    3204838     0
     49221     0     0   73207050      49662     0    3317415     0
     47356     0     0   70485776      47766     0    3188565     0
     24723     0     0   36742535      24931     0    1663964     0
      7792     0     0   11546882       7867     0     526188     0
      2904     0     0    4271329       2940     0     197170     0
      3968     0     0    5830030       4026     0     270300     0
      4050     0     0    5926199       4105     0     277123     0
      5439     0     0    7989480       5529     0     371653     0
      4856     0     0    7118347       4947     0     333140     0
      3621     0     0    5264896       3697     0     250138     0
      2481     0     0    3623731       2528     0     170544     0
     27065     0     0   39936214      27398     0    1839155     0
     37315     0     0   55502193      37655     0    2512900     0
     33134     0     0   49215242      33431     0    2233491     0
     29167     0     0   43345555      29417     0    1962069     0
     30076     0     0   44759860      30325     0    2021645     0
     30767     0     0   45805439      31027     0    2068040     0
     34063     0     0   50751408      34337     0    2288251     0
     29257     0     0   43632988      29508     0    1966238     0
      8441     0     0   12510795       8552     0     571887     0
      7168     0     0   10588271       7277     0     487875     0
      5668     0     0    8157194       5809     0     396740     0
      3909     0     0    5629505       4014     0     270872     0
      3433     0     0    4945055       3524     0     237241     0
^C
here it is some traffic "waves"
a few moments later
# netstat -w1d
      7930     0     0   11669281       8044     0     537093     0
      6918     0     0   10158181       7050     0     472957     0
         7     0     0        518          4     0        392     0
         6     0     0        374          3     0        350     0
         5     0     0        356          4     0        968     0
       263     0     0     381047        259     0      17868     0
      5376     0     0    7823391       5474     0     367900     0
      4461     0     0    6531401       4560     0     304577     0
and system is gone again.
What might it be? Sata controllers? Network adapter?
DJ9
More than likely you'll need to ditch your add-on cards and try something that works. When you mentioned JMicron and Promise cards that made me cringe. (they generally suck in BSD)
