pclausen
 - Apr 19, 2015
So I took my FreeNAS box down to upgrade the CPU.  It all went well and it came right back up and my Emby and transmission plugs started up and are running fine, but Sickrage did not.  I tried using the button in the FreeNAS gui to start it, but it failed.  Restarted the Sickrage jail, still nothing.
So I tried to start if from the command line and got this:
Here are the lines from the kat.py file:
Any ideas?
root@sickrage_1:/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/providers # service sickrage start
Starting sickrage.
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/SickBeard.py", line 58, in <module>
    import sickbeard
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/__init__.py", line 37, in <module>
    from sickbeard import providers
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/providers/__init__.py", line 19, in <module>
    from sickbeard.providers import btn, newznab, womble, thepiratebay, torrentleech, kat, iptorrents, torrentz, \
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/providers/kat.py", line 184, in <module>
    provider = KATProvider()
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/providers/kat.py", line 52, in __init__
    'search': base_url + '%s/',
NameError: global name 'base_url' is not defined
/usr/local/etc/rc.d/sickrage: WARNING: failed to start sickrage
root@sickrage_1:/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/providers #Here are the lines from the kat.py file:
# coding=utf-8
# Author: Mr_Orange <mr_orange@hotmail.it>
# URL: http://code.google.com/p/sickbeard/
# This file is part of SickRage.
# SickRage is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# SickRage is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with SickRage.  If not, see <http://www.gnu.org/licenses/>.
import traceback
from urllib import urlencode
import xmltodict
import HTMLParser
import sickbeard
from sickbeard import logger
from sickbeard import tvcache
from sickbeard.common import USER_AGENT
from sickbeard.providers import generic
from xml.parsers.expat import ExpatError
class KATProvider(generic.TorrentProvider):
    def __init__(self):
        generic.TorrentProvider.__init__(self, "KickAssTorrents")
        self.supportsBacklog = True
        self.public = True
        self.confirmed = True
        self.ratio = None
        self.minseed = None
        self.minleech = None
        self.cache = KATCache(self)
        self.urls = {
            'base_url': 'https://kickass.unblocked.la/',
        self.url = self.urls['base_url']
        self.headers.update({'User-Agent': USER_AGENT})
        self.search_params = {
            'q': '',
            'field': 'seeders',
            'sorder': 'desc',
            'rss': 1,
            'category': 'tv'
        }Any ideas?
