I need some help figuring out if I set something up wrong or if there's something wrong with my FN box.
FN box is 8.0.4p2 64 bit, Pen G620, 16g, about 2 months old. FN box name is "tuck". Basic home setup is that I have 3 computers and the FN box. One Win7 box to do dvd rips/processing and 2 macs (One 10.7.4, one 10.8) for viewing/sharing iTunes. I use one username "joshnerl" to access the FN box from all computers.
When I setup tuck, i setup one volume called "tuckmov" for all my movies, tv shows, etc. I setup another for time machine and basic storage called tuckstor. Then I setup both CIFS and AFP shares to the same path for movies - in other words, I made a tuckmovafp and a tuckmovcifs and they both go directly to /mnt/tuckmov/. Finally I setup time machine to run to a volume in tuckstor called tm.
Here's my problem. Since I started this new box, the logging has been spitting out a lot of messages and I'm not smart enough to know if they're a problem or not. Stuff like this:
Aug 3 08:33:59 tuck last message repeated 23 times
Aug 3 08:33:59 tuck afpd[41962]: dsi_stream_read: len:0, unexpected EOF
Aug 3 08:33:59 tuck afpd[41962]: dsi_disconnect: entering disconnected state
Aug 3 08:33:59 tuck afpd[42153]: AFP3.3 Login by joshnerl
Aug 3 08:33:59 tuck afpd[42153]: afp_disconnect: trying primary reconnect
Aug 3 08:33:59 tuck afpd[2023]: Reconnect: transfering session to child[41962]
Aug 3 08:33:59 tuck afpd[2023]: Reconnect: killing new session child[42153] after transfer
Aug 3 08:33:59 tuck afpd[41962]: afp_dsi_transfer_session: succesfull primary reconnect
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43231 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43232 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43233 / cmd: AFP_GETFLDRPARAM
Aug 3 08:33:59 tuck afpd[41962]: sys_getextattr_size: error: Result too large
Aug 3 08:33:59 tuck last message repeated 33 times
Aug 3 08:33:59 tuck afpd[42154]: AFP3.3 Login by joshnerl
Aug 3 08:33:59 tuck afpd[42154]: afp_disconnect: trying primary reconnect
Aug 3 08:33:59 tuck afpd[2023]: Reconnect: killing new session child[42154] after transfer
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43348 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43349 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[42145]: afp_disconnect: primary reconnect succeeded
Aug 3 08:33:59 tuck last message repeated 5 times
Aug 3 08:33:59 tuck afpd[42155]: AFP3.3 Login by joshnerl
Aug 3 08:33:59 tuck afpd[42155]: afp_disconnect: trying primary reconnect
Aug 3 08:33:59 tuck afpd[2023]: Reconnect: killing new session child[42155] after transfer
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43380 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[41962]: AFP Replay Cache match: id: 43381 / cmd: AFP_LISTEXTATTR
Aug 3 08:33:59 tuck afpd[42146]: afp_disconnect: primary reconnect succeeded
Aug 3 08:34:00 tuck afpd[41962]: sys_getextattr_size: error: Result too large
Aug 3 08:34:00 tuck afpd[41962]: dsi_stream_read: len:0, unexpected EOF
Aug 3 08:34:00 tuck afpd[41962]: dsi_disconnect: entering disconnected state
Aug 3 08:34:00 tuck afpd[42157]: AFP3.3 Login by joshnerl
Aug 3 08:34:00 tuck afpd[42157]: afp_disconnect: trying primary reconnect
Aug 3 08:34:00 tuck afpd[2023]: Reconnect: transfering session to child[41962]
Aug 3 08:34:00 tuck afpd[2023]: Reconnect: killing new session child[42157] after transfer
Aug 3 08:34:00 tuck afpd[41962]: afp_dsi_transfer_session: succesfull primary reconnect
Aug 3 08:34:00 tuck afpd[41962]: AFP Replay Cache match: id: 43396 / cmd: AFP_LISTEXTATTR
Aug 3 08:34:00 tuck afpd[42147]: afp_disconnect: primary reconnect succeeded
Aug 3 08:34:00 tuck afpd[42160]: AFP3.3 Login by joshnerl
Aug 3 08:34:00 tuck afpd[42160]: afp_disconnect: trying primary reconnect
Aug 3 08:34:00 tuck afpd[2023]: Reconnect: killing new session child[42160] after transfer
Aug 3 08:34:00 tuck afpd[41962]: AFP Replay Cache match: id: 43409 / cmd: AFP_LISTEXTATTR
Aug 3 08:34:00 tuck afpd[42148]: afp_disconnect: primary reconnect succeeded
Aug 3 08:34:00 tuck last message repeated 15 times
Aug 3 08:34:00 tuck afpd[42161]: AFP3.3 Login by joshnerl
Aug 3 08:34:00 tuck afpd[42161]: afp_disconnect: trying primary reconnect
Aug 3 08:34:00 tuck afpd[2023]: Reconnect: killing new session child[42161] after transfer
Aug 3 08:34:00 tuck afpd[41962]: AFP Replay Cache match: id: 43463 / cmd: AFP_LISTEXTATTR
Now i never get more than 10-15 minutes between line items - ever. It's like there's constant heartbeat checks or something. About two weeks ago, my macs stopped showing artwork associated with the movie files in iTunes. When I do a "get info" on the individual files in itunes, the artwork shows back up. Then on one of my macs (10.7.4), I'm now getting a message about every 3 days that it wants to create a new time machine backup because there was something wrong with the old one. I let it recreate the backup on 7/31 and now it's telling me it wants to do it again. Last straw is that I have my macs connect automatically to tuck when they startup. In the last week or so, when I sit down at one of them, tuck isn't mounted. It's like it connects on startup, then loses it at some point.
Bottom line question is did i mess something up by pointing both AFP and CIFS shares to the same directory, do I have a problem with my files, is there a problem with AFP on FN? I just need some help deciding which rabbit hole to dive into. Any help or troubleshooting advice would be appreciated.
Josh
Josh
