AFP issues
Pr0jektCha0s
So about 2 weeks ago I updated to FreeNAS-9.10.1-U2. Since then I'm unable to connect to my Time Machine AFP share. I've searched for these errors in the forums, but I don't see answers to the problem. I have 3 Time Machine shares my systems have been backing up to. None of them work anymore.
The configurations are unchanged. I did reboot the Freenas server in hopes of clearing it up, but no go. Here are the few logs that I get when attempting to connect.
Oct 22 23:44:47 freenas afpd[13703]: AFP logout by MBP13
Oct 22 23:44:47 freenas afpd[13703]: dsi_stream_read: len:0, unexpected EOF
Oct 22 23:44:47 freenas afpd[13703]: afp_over_dsi: client logged out, terminating DSI session
Oct 22 23:44:47 freenas afpd[13703]: AFP statistics: 0.59 KB read, 0.48 KB written
Any info would be helpful. Thanks!
Stux
FWIW, it does work for me on U2.
You should check that you can manually login via AFP.
Ie "connect to server" then
afp://<server ip>
D
dlavigne
Guest
In that case, please create a bug report at bugs.freenas.org and post the issue number here. It would be useful to include a debug with the report (you can make that using System -> Advanced -> Save Debug).
