snpz
- Oct 13, 2017
Hi!
Had Freenas 9.10 running for more than a year with two 1gbit ETH interfaces in lagg. Works perfect, but decided to move on and installed into the box Intel XXV710-DA2 Network Card (25G 2 port SFP+).
Upgraded to Freenas v11, but dont see that this NIC would be recognized by the system.
lspci shows:
02:00.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05)
02:01.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05)
04:00.0 Ethernet controller: Intel Corporation Device 158b (rev 02)
04:00.1 Ethernet controller: Intel Corporation Device 158b (rev 02)
Not sure how to install kernel modules for this NIC, because it is not possible to install them "Intel way", cos there is no kernel source in FreeNAS.
May be there are modules and i am doing something terribly wrong?
Thanks in advance!
Martins
p.s. Used to work with linux, so im a bit confused about everything in freebsd :)
lspci shows:
Thanks in advance!
Martins
