Add HDDs to raidz1
Charlie86
Currently my freenas box have 5x3TB in raidz1 configuration. I just added two more 3TBs.
Is it possible just to add them to existing pool or must I build new pool and migrate data to external drives?
Thanks.
You have two choices - Rebuild the vdev to include 7 disks or add a second vdev (strongly recommend 3TB mirrored for redundancy) to the pool. If you must stay with RAIDZ1, the former will give you an additional 6TB; the latter 3TB.
