ada4 error
gearhead
I am getting the following error message on ada4. Does ada4 refer to sata port number 4?
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 1d e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): CAM status: Command timeout
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): Error 5, Periph was invalidated
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 1e e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): CAM status: Unconditionally Re-queue Request
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 1f e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 20 e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 21 e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 22 e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 23 e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 (ada4:ahcich6:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 30 24 e5 40 42 00 00 01 00 00
Jun 19 10:27:51 freenas11 GEOM_MIRROR: Device swap0: provider ada4p1 disconnected.
pro lamer
joeschmuck
Old Man
Absolutely not. If you want to find out which drive it is, at the command prompt type smartctl -a /dev/ada4 and the drive will spit out some data, one piece near the top is the drive serial number. Use this to identify the physical drive. Next, post the output of that command here for analysis, or refer to my link in my signature line to Troubleshoot Hard Drive Guide.
While a very good reference, it's likely a bit too much given the question at hand.
gearhead
thanks guys
