kyle_macaulay
 - Dec 9, 2022
Hello everyone,
@anodos you appear to be the SME on active directory so figured I'd request your assistance if you have the time.
I've had my truenas system successfully joined to my domain for quite some time. Out of nowhere, I'm having an issue I can't seem to wrap my head around. I logged in and noticed I was no longer connected to my domain so I attempted to reconnect the domain and I constantly get answers along the lines of below:
Below is what I have gathered in my request for assistance on this issue please let me know what else i may need.
I have found I can force it to start and go to a joining state by running midclt call activedirectory.start
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 196, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call
  File "/usr/lib/python3/dist-packages/middlewared/service.py", line 576, in update
    rv = await self.middleware._call(
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/activedirectory.py", line 434, in do_update
    await self.middleware.call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/activedirectory_/dns.py", line 211, in check_nameservers
    servers = await self.middleware.call('dnsclient.forward_lookup', {
  File "/usr/lib/python3/dist-packages/middlewared/plugins/dns_client.py", line 96, in forward_lookup
    results = await asyncio.gather(*[
  File "/usr/lib/python3/dist-packages/middlewared/plugins/dns_client.py", line 40, in resolve_name
    ans = await r.resolve(
  File "/usr/lib/python3/dist-packages/dns/asyncresolver.py", line 134, in resolve
    (answer, done) = resolution.query_result(response, None)
  File "/usr/lib/python3/dist-packages/dns/resolver.py", line 641, in query_result
    raise NoAnswer(response=answer.response)
dns.resolver.NoAnswer: The DNS response does not contain an answer to the question: _gc._tcp.MACAULAY.COM. IN SRV
root@Truenas[~]# host -t srv _ldap._tcp.macaulay.com _ldap._tcp.macaulay.com has SRV record 0 100 389 domaincont.macaulay.com.
root@Truenas[~]# net ads lookup -S macaulay.com
Information for Domain Controller: 192.168.0.76
Response Type: LOGON_SAM_LOGON_RESPONSE_EX
GUID: 41234c7a-68a6-4a11-9699-17081b5e6e37
Flags:
        Is a PDC:                                   yes
        Is a GC of the forest:                      yes
        Is an LDAP server:                          yes
        Supports DS:                                yes
        Is running a KDC:                           yes
        Is running time services:                   yes
        Is the closest DC:                          yes
        Is writable:                                yes
        Has a hardware clock:                       yes
        Is a non-domain NC serviced by LDAP server: no
        Is NT6 DC that has some secrets:            no
        Is NT6 DC that has all secrets:             yes
        Runs Active Directory Web Services:         yes
        Runs on Windows 2012 or later:              yes
Forest: macaulay.com
Domain: macaulay.com
Domain Controller: DomainCont.macaulay.com
Pre-Win2k Domain: MACAULAY
Pre-Win2k Hostname: DOMAINCONT
Server Site Name: Default-First-Site-Name
Client Site Name: Default-First-Site-Name
NT Version: 5
LMNT Token: ffff
LM20 Token: ffffI have found I can force it to start and go to a joining state by running midclt call activedirectory.start
