A new message with 11.1-RC1 and now 11.1, 11.1-U1, 11.1-U2, too
g---man
sorry about that, it was downloading the whole page, obviously that's useless here since we just need the code from that 1 file, here's the magic
cd /usr/local/etc/consul-checks/
rm freenas*
wget https://raw.githubusercontent.com/freenas/freenas/8175ddd35c189c43c47a51e42a1353e96d9ac2cb/src/freenas/usr/local/etc/consul-checks/freenas_health.sh
chmod a+x freenas_health.sh
Thanks, problem solved.
If anyone still questioning solution, here is the diff between old and new files:
root@freenas:/usr/local/etc/consul-checks # diff freenas_health.sh.backup freenas_health.sh
14a15,17
> if [ -z $line ] ; then
> continue
> fi
17c20
< continue
> continue
So nothing malicious here.
Chronic
rm freenas*
Just tried this on my U1 (not a fresh install) and it's still spamming. The sh-file IS changed but that doesn't seem to make any difference whatsoever. :(
phlmike18
I used this fix:
rm freenas*
And it works, except does not survive a reboot. I looked at the redmine bug report but I don't see an answer and it looks like it won't be out until FreeNAS 11.2. If it is as simple as a fixed script why can't it make the next release which looks like 11.1-U2 in 12 days... So we have to wait 90 days to get this fixed.
Unless this isn't a fix just a bandaid.
Chris Moore
Do you you know why?
Why it works or why it doesn't survive a reboot?
It doesn't survive a reboot because the file in question is not intended to be user modifiable and is therefore reloaded from a static image when the system is booted. You are only able to modify it at all because it is available to the system during run-time. The changes are discarded when the system is shutdown and a fresh (from the image) version of the file is loaded during the boot process. Many of the files that are not meant to be tampered with work that way.
Faluzure
I used this fix:
rm freenas*
Well 11.1-U2 is out and it's still not resolved. Doing some digging on the forums, user Redcoat stated this fix is now slated for 11.2: https://forums.freenas.org/index.ph...ystem-is-in-warning-status.59766/#post-439760
Chris Moore
Faluzure
Did you upgrade? I did. I am using 11.1-U2 and I have no problems, none at all.
I have only heard some complaints about the New UI. I don't have a problem with that because I don't use it.
Hello, I did upgrade and am running 11.1-U2. Overall, it's functioning exactly like the previous version but I still have those errors. in regards to 'freenas_health' is now warning. I don't mind it at all, was just updating this thread. Apparently what Redcoat says is true, as this bug shows the target version is now 11.2: https://redmine.ixsystems.com/issues/26355
Chris Moore
That is odd because I have not seen the error message since the upgrade.
Skyfox
I have upgraded to 11.1-U2 and am also still getting the message, have spoken to at least one other is still receiving the error.
Faluzure
Yeah. Like I said, it's not a big deal and it's not a show-stopper. But like other people, it's alarming to see your logs spam you with the same message over & over, even if it is cosmetic. I'll just wait until 11.2 and cross my fingers it's fixed.
Count me as the 3rd getting the error.
Redcoat
Something to try - run
/usr/local/bin/midclt call notifier.get_alerts
and see what's causing the "alarms". Maybe they are not "errors".
Skyfox
Just the warning for being over 80% use of space. (it's at 84%)
Redcoat
So, in your case, that's not "an error". Similarly I had the warning when (a) an update was available and (b) because I had not updated the ZFS feature flags - satisfy those two, warning gone.
From the bug report I infer that the warning may not disappear if such items are present, but that it may indicate what they are.
Skyfox
A fair point, but as far as I know it was not a new feature to have it spam logs every 2 minutes if there is an alert, so I'm still inclined to see this as an error. I'll work on getting my storage down to 80% and see if that removes the message.
TFAiSO
I want to put it out there that I was able to upgrade (via GUI) from 9.10.2-U6 to 11.1-RC1 without a hitch. But I also have this wonderful non-warning warning in /var/log/messages ... every two minutes. Otherwise, brilliant that the upgrade worked and looking forward to the real release Release and subsequent 11.2 with iocage via GUI.
I am also getting the same error message from consul, giving me a health warning. The health icon in the GUI, top-right, is flashing red. In the login console, I see CBB error for /dev/da0. I just did a smartctl long self-test on /dev/da0 and it says nothing is wrong with my hard drive. What could this be? I'm running FreeNAS-11.1-U1 fresh install, and the consul runs here for sure.
I have just done the fix wgetting the new file, and no more error messages. :)
Then the system thinks you've got a problem. What message do you get if you click on the health icon?
Faluzure
I know U4 came out the other day. Just letting everyone know that the error is now gone since upgrading to U4.
