Ok, I have an idea of building two separate NAS system. One of them would be made of a few disks in ZFS Z2 pool for personal documents. Four to five hard drives could be smaller then 3tb. Data on them would be software iso images, installations, backups, personal documents and personally created multimedia. I thing that for many years ahead 4 or 5 (-2) 2tb drives would be enough.
Other one would be also 4-5 disks system, with movies and series, 3tb disks z1 pool with big files. I have not yet decided what system should I build first and should I combine them as two pools in same system. I would build it with cheaper ITX or mATX case.
For two separate systems I have two computers that work independently with separate ethernet ports, separate processing power and separate memory. On the other hand with faster hardware and good big case and cooling it could be cheaper on the end.
My questions:
How much memory does zfs really need? Do I need to go for 16GB board with i3 or would it be sufficient to take 8GB board with athlon or maybe even Atom or similar? Does the number or size of files need to be considered for specific memory and processor needs? Do I need an UEFI board, to be able to add the 3tb and 4tb disks to vdev pools or can the regular board do it too?
Regards,
Sasa
My questions:
Regards,
Sasa
