Hi all,
I made a clean FreeNAS 9.3 install and configured LDAP in the GUI. The problem : I cannot see any domain users. With freenas-debug -l I could see the LDAP settings are empty. What is wrong?
Thanks in advance
steini
[root@freenas] ~# freenas-debug -l
+ FreeNAS-9.3-STABLE-201412142326 +
Operating system type: FreeBSD
Operating system release: 9.3-RELEASE-p5
Operating system revision: 199506
Kernel version: FreeBSD 9.3-RELEASE-p5 #0 3b4abc3: Sun Dec 14 12:56:11 PST 2014
root@build3.ixsystems.com:/tank/home/jkh/build/93/FN/objs/os-base/amd64/fusion/jkh/93/FN/FreeBSD/src/sys/FREENAS.amd64
Hostname: freenas.msdev.intern.testdomain.de
Name of kernel file booted: /boot/kernel/kernel
+ LDAP Status +
LDAP is ENABLED
Error: no such column: ldap_use_default_domain
+ LDAP Settings +
Hostname:
Base DN:
Bind DN:
Anonymous Bind:
User Suffix:
Group Suffix:
Password Suffix:
Machine Suffix:
SUDO Suffix:
Use Default Domain:
SSL:
Samba Schema:
Thanks in advance
steini
+ LDAP Status +
LDAP is ENABLED
+ LDAP Settings +
Hostname:
Base DN:
Bind DN:
Anonymous Bind:
User Suffix:
Group Suffix:
Password Suffix:
Machine Suffix:
SUDO Suffix:
Use Default Domain:
SSL:
Samba Schema:
