Hi there,
This is my first time attempting to deploy FreeNAS, so please forgive any obvious stupidity.
Anyway, I'm trying to run FreeNAS on a crappy acer prebuilt (i3 3220, 8gb DDR3, 1Tb WD spinning disk, generic 16Gb Boot USB flash drive, highly inadvisable hardware I'm sure) to run a few test as a precursor to a possible 45 Drives 'storinator' deployment at my work. I tried to install 9.10.1-U2 onto the WD drive in the machine from the USB that is now the boot drive, which spat an error (unfortunately I don't remember this error as I didn't think much of it at the time). When this failed, I attempted to install 9.10.1-U2 onto the USB from a 16Gb SD card, this spat the same error.
The next day, I decided to try installing to the USB from the SD card via my MacBook, which worked flawlessly. So I fire up the USB on the test Acer machine, and some time after the machine being assigned an IP address, I get the error 'getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs'. This error grinds the boot to a halt and will re print every 30 seconds (who'd have thought it hey ;))
Anyway, after some suggestions on similar issues that it could be a filing USB stick, I installed 9.10.1-U2 on another 32GB USB Flash drive I had lying around, exact same issue.
Interestingly, I get this error wether I give the machine an ethernet connection or not...
Any advice would be massively appreciated!!
Cheers, Jake
Cheers, Jake
