6 unassigned disks
IllSkillz
I have two pools and 6 unassigned disks just randomly showed up. 5 from one pool and 1 from another.
Arwen
It would appear their is a bug in the GUI. Adding the disks will likely corrupt an existing pool, as well as the pool added to.
Isma
When I had ghost disks, in my case I exported the pool and reimported it. You can reconsider the idea and see if updating the pool solves it.
IllSkillz
After system restart, pools lost the devices. is there a way to reattach them back?
IllSkillz
it seems that disks lost there uuid
is it possible that that happened because I did fio on disk whyle it was in the pool ?
IllSkillz
I tested it and i can confirm that running fio on a disk that is attached to the pool will make that disk dropout from the pool
