I have two pools and 6 unassigned disks just randomly showed up. 5 from one pool and 1 from another.
I IllSkillz Dabbler Joined Feb 21, 2023 Messages 22 Nov 5, 2023 #1 I have two pools and 6 unassigned disks just randomly showed up. 5 from one pool and 1 from another. Attachments 1699236943413.png 63.1 KB · Views: 517 1699236975868.png 29 KB · Views: 479
I IllSkillz Dabbler Joined Feb 21, 2023 Messages 22 Nov 5, 2023 #2 I wonder what would happen if I add those disks in to existing pool? More free space? )
Arwen MVP Joined May 17, 2014 Messages 3,611 Nov 5, 2023 #3 It would appear their is a bug in the GUI. Adding the disks will likely corrupt an existing pool, as well as the pool added to.
Isma Contributor Joined Apr 29, 2020 Messages 100 Nov 6, 2023 #4 When I had ghost disks, in my case I exported the pool and reimported it. You can reconsider the idea and see if updating the pool solves it.
I IllSkillz Dabbler Joined Feb 21, 2023 Messages 22 Nov 6, 2023 #5 After system restart, pools lost the devices. is there a way to reattach them back?
I IllSkillz Dabbler Joined Feb 21, 2023 Messages 22 Nov 6, 2023 #6 it seems that disks lost there uuid is it possible that that happened because I did fio on disk whyle it was in the pool ? Attachments 1699314274033.png 152.3 KB · Views: 516 Last edited: Nov 6, 2023
I IllSkillz Dabbler Joined Feb 21, 2023 Messages 22 Nov 7, 2023 #7 I tested it and i can confirm that running fio on a disk that is attached to the pool will make that disk dropout from the pool
