- Dec 21, 2012
Tried to upgrade from 22.02.2.1 -> 22.02.4 and after can no longer decrypt a pool.
This specific pool lives on a disk shelf (DS4246) with a single controller , connected to a Supermicro motherboard using LSI SAS9200-8e and a single cable from the shelf to the controller.
After the upgrade everything looked ok, however I then tried to unlock a dataset and that is where all hell broke loose. Once I put in the passphrase to unlock and press ok i start to get a bunch of read errors shown below. My other 2 pools not on this disk shelf are working fine.
So far I have tried the following.
At this point not sure what else to do maybe get a new sas controller, and hope that fixes it? Open to ideas. Also below is a bit more detail on timing. The pool starts fine, its only after unlocking does it freak out.
BEFORE Unlock
After Unlocking
- Swapped the SAS cable with a new one , restart reboot same failure
- Unplugged the top controller on the disk shelf, installed the 2nd one in the middle slot of the disk shelf, restart reboot same problem.
- Removed a 10GB NIC that was sorta close to the HBA thinking maybe heat, restart reboot same problem.
- Connected the sas cable to the top port instead of the bottom port on the SAS9200-8e, restart reboot same problem.
BEFORE Unlock
root@Vault:~# zpool status Infinity -v
pool: Infinity
state: ONLINE
scan: resilvered 532K in 00:00:00 with 0 errors on Fri Jul 22 17:52:27 2022
NAME STATE READ WRITE CKSUM
Infinity ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
ad4febd2-9418-4c98-9a29-6009d93d477d ONLINE 0 0 0
d1ae15bd-ea73-4e35-9343-dedd8bbe0e6f ONLINE 0 0 0
40bc676e-1411-4fb8-9b2a-e9d62af1dee4 ONLINE 0 0 0
c8d40c54-0498-49f5-95c7-dfebd5e349a4 ONLINE 0 0 0
3472a6bf-91c2-4e73-92fe-76479307e952 ONLINE 0 0 0
84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d ONLINE 0 0 0
00f5e183-37a3-4053-964c-e39ae771f17d ONLINE 0 0 0
4c39c9db-3bd8-4705-96df-d2f182efd75e ONLINE 0 0 0
0911d6f0-cac5-4a1f-92d0-f334e399eab4 ONLINE 0 0 0
f3c2cd4a-c2a2-487f-baec-0af0f17d1de8 ONLINE 0 0 0
16926f72-01a9-43ae-b08b-5bc0a90d80d6 ONLINE 0 0 0
7dbe4bb7-80a6-4557-ae68-19b21f176a4d ONLINE 0 0 0
errors: No known data errors
After Unlocking
pool: Infinity
state: ONLINE
status: One or more devices are faulted in response to IO failures.
action: Make sure the affected devices are connected, then run 'zpool clear'.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-JQ
raidz2-0 ONLINE 3 0 0
ad4febd2-9418-4c98-9a29-6009d93d477d ONLINE 4 0 0
c8d40c54-0498-49f5-95c7-dfebd5e349a4 ONLINE 4 0 0
3472a6bf-91c2-4e73-92fe-76479307e952 ONLINE 4 0 0
84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d ONLINE 4 0 0
00f5e183-37a3-4053-964c-e39ae771f17d ONLINE 4 0 0
4c39c9db-3bd8-4705-96df-d2f182efd75e ONLINE 4 0 0
0911d6f0-cac5-4a1f-92d0-f334e399eab4 ONLINE 4 0 0
16926f72-01a9-43ae-b08b-5bc0a90d80d6 ONLINE 4 0 0
7dbe4bb7-80a6-4557-ae68-19b21f176a4d ONLINE 4 0 0
errors: List of errors unavailable: pool I/O is currently suspended
root@Vault:~# tail -f /var/log/messages Mar 17 12:43:36 Vault kernel: sdan: sdan1 sdan2 Mar 17 12:43:36 Vault kernel: sd 0:0:25:0: [sdao] Attached SCSI disk Mar 17 12:43:36 Vault kernel: sdam: sdam1 sdam2 Mar 17 12:43:36 Vault kernel: sd 0:0:24:0: [sdan] Attached SCSI disk Mar 17 12:43:36 Vault kernel: sdaj: sdaj1 sdaj2 Mar 17 12:43:36 Vault kernel: sd 0:0:23:0: [sdam] Attached SCSI disk Mar 17 12:43:36 Vault kernel: sdal: sdal1 sdal2 Mar 17 12:43:36 Vault kernel: sd 0:0:20:0: [sdaj] Attached SCSI disk Mar 17 12:43:36 Vault kernel: sd 0:0:22:0: [sdal] Attached SCSI disk Mar 17 12:46:35 Vault kernel: cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation <INSERTED THIS LINE HERE, NOTICE THESE ERRORS AFTER UNLOCKING> Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d error=5 type=1 offset=7307039215616 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/84d7b5d5-38ab-4dc2-8b54-d42b1836aa3d error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/c8d40c54-0498-49f5-95c7-dfebd5e349a4 error=5 type=1 offset=7307039215616 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/3472a6bf-91c2-4e73-92fe-76479307e952 error=5 type=1 offset=7307039215616 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/c8d40c54-0498-49f5-95c7-dfebd5e349a4 error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/3472a6bf-91c2-4e73-92fe-76479307e952 error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/c8d40c54-0498-49f5-95c7-dfebd5e349a4 error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/3472a6bf-91c2-4e73-92fe-76479307e952 error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/c8d40c54-0498-49f5-95c7-dfebd5e349a4 error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/3472a6bf-91c2-4e73-92fe-76479307e952 error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/0911d6f0-cac5-4a1f-92d0-f334e399eab4 error=5 type=1 offset=7156744179712 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/0911d6f0-cac5-4a1f-92d0-f334e399eab4 error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/0911d6f0-cac5-4a1f-92d0-f334e399eab4 error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/0911d6f0-cac5-4a1f-92d0-f334e399eab4 error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/00f5e183-37a3-4053-964c-e39ae771f17d error=5 type=1 offset=7156744179712 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/4c39c9db-3bd8-4705-96df-d2f182efd75e error=5 type=1 offset=7156744179712 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/00f5e183-37a3-4053-964c-e39ae771f17d error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/4c39c9db-3bd8-4705-96df-d2f182efd75e error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/00f5e183-37a3-4053-964c-e39ae771f17d error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/4c39c9db-3bd8-4705-96df-d2f182efd75e error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/00f5e183-37a3-4053-964c-e39ae771f17d error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/4c39c9db-3bd8-4705-96df-d2f182efd75e error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/ad4febd2-9418-4c98-9a29-6009d93d477d error=5 type=1 offset=7308429172736 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/ad4febd2-9418-4c98-9a29-6009d93d477d error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/ad4febd2-9418-4c98-9a29-6009d93d477d error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/ad4febd2-9418-4c98-9a29-6009d93d477d error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/16926f72-01a9-43ae-b08b-5bc0a90d80d6 error=5 type=1 offset=7308429168640 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/16926f72-01a9-43ae-b08b-5bc0a90d80d6 error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/7dbe4bb7-80a6-4557-ae68-19b21f176a4d error=5 type=1 offset=7308429168640 size=4096 flags=180880 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/16926f72-01a9-43ae-b08b-5bc0a90d80d6 error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/7dbe4bb7-80a6-4557-ae68-19b21f176a4d error=5 type=1 offset=270336 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/16926f72-01a9-43ae-b08b-5bc0a90d80d6 error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/7dbe4bb7-80a6-4557-ae68-19b21f176a4d error=5 type=1 offset=9794672140288 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: zio pool=Infinity vdev=/dev/disk/by-partuuid/7dbe4bb7-80a6-4557-ae68-19b21f176a4d error=5 type=1 offset=9794672402432 size=8192 flags=b08c1 Mar 17 12:49:00 Vault kernel: WARNING: Pool 'Infinity' has encountered an uncorrectable I/O failure and has been suspended.
