12.0-U8 Randomly locks up | Threadripper - ASrock Mobo - 256G
lightingman117
TR-3970x, ASRock TRX40D8-2N2T, 256GB-SS32GBDDR4ECC3200 @ 3200 (slight OC), 512TB 970Pro (mirror), 1000w Redundant Plat, SAS3008, X710, 12x 16TB EX16
I recently upgraded to U8 to see if some of the AMD specific bug fixes would help.
I have run HCI MemTest up to 300%
I have run windows 10 on it with TM5 (Test Mem, extreme config)
Latest BIOS/IPMI available from ASRock
Usage is minimal ~100Mib/s at most
I have no crashes unless running FreeBSD/TrueNAS, so to me, the hardware seems in order.
I added tunables:
watchdogd_enable|no|RC|disable IPMI watchdog
kern.corefile|/var/coredumps/%U/%N.core|SYSCTL|store logs in debu file
But neither seem to do anything.
I've poured over the logs and don't see or notice anything.
When it locks up, it locks up so hard that nothing works and a hard reboot is required.
Seems to happen every 1wk-4wks.
What logs are safe to upload (no user data) and beneficial?
  • TrueNAS2_boot log.txt
1337Hacker
Jesus that's a system, especially that 512TB 970Pro :wink:
I take it you hot swapped a drive on the 5th?
When did you hard reset the box?
Pull up the terminal and post what you see
cd /data/crash
ls -al
LarsR
did you make the bios changes for ryzen cpu?
Disable amd cool&quiet erp-ready und global c-states
lightingman117
cd /data/crash
ls -al
Yeaaa, *sheepishly grins* New to TrueNAS, a bit overkill I guess. 128GB drives probably woulda been 'fine' for the boot-pool/system drive.
Disk6: probably, I had a 2nd vdev/tank not used that I was waiting on new drives to make it a full 6 drives. I don't remember exactly when that occurred though.
Crash: Apr 6 08:31:24 is when it came back up. So sometime between the config load at midnight and ~8am it crashed.
I ran the code, I don't see how I didn't find this as I poked in all the folders in shell (timidly tho as I'm new to FreeBSD/Linux CLI stuffs).
I compressed the folder, I'm trying to figure out how to move it onto my computer for viewing instead of in MC... So far no luck with copying to the var/log directory and downloading debug logs, copying to /mnt/storage repo, copying to remote host...
Edit: Copying to var/log & downloading debug logs worked. (was looking in wrong folder).
Shortly after I made this post I found a similar thread to this one discussing C-States:
I found global c-states in the bios; but didn't think to do cool & quiet or erp-ready.
I will do this now.
Been up 5 days, but that's normal.
I also moved the 2x 50TB vdevs over to another older intel based TrueNAS build for the time being (they need to be in production).
NugentS
Given its a server and not a games machine. I would remove the OC on the memory for even a fraction increased stability
lightingman117
I would typically agree, server stability > performance.
But thus-far, no data indicates it is a memory issue.
And thus ensues a "what is technically an OC" conversation.
[Who says what OC is? AMD, ASRock QVL, Memory QVL?]
For completeness;
Mobo QVL says 128 ECC is okay up to 3200, but 256 should drop down to 2666
BIOS repots PN: W724GU44J2320NA for RAM, sticks say SS32GBDDR4ECC3200 SST.
Neither are on the QVL and it is what the MFG sent us, so there's not much I can do there.
I am running 3000/1500 (MCLK/IF).
Tested with various memory programs for many days to ensure stability.
I don't see any reason to change if there's no data to suggest this is the culprit.
For the record, I have a nearly identical (minus HBA) system running Win Server @ 3200/1600 with perfect up-time. It is running a custom FFMPEG based video server.
lightingman117
cd /data/crash
ls -al
Here are the files moved/extracted to my machine
And the "textdump.tar.0.gz" file with some heaft.
Panic.txt
VERIFY3(c < SPA_MAXBLOCKSIZE >> SPA_MINBLOCKSHIFT) failed (36028797018963967 < 32768)
What I don't get is all of these crash files are from Jan. We have had at least 3 crashes since then. Where are those logs?
I was able to adjust the following:
Advanced > Amd CBS > CPU Common Options > Global C-state Control [disabled]
Advanced > Amd CBS > CPU Common Options > Core Watchdog > Timer Enable [disabled]
Advanced > Amd CBS > CPU Common Options > Core Performance Boost [disabled]
Advanced > Amd CBS > CPU Common Options > Power Supply Idle Control [typical current idle]
Advanced > Amd CBS > NBIO Common Options > SMU Common Options > DF Cstates > Disable (cool'n'quiet?)
Advanced > Amd Overclocking > Precision Boost Overdrive > [Disable]
Advanced > Amd Overclocking > SoC/Uncore OC Mode > [Enabled]
lightingman117
I have had 79 days of uptime.
I consider this resolved. (fixed with last post)
Thank you!
Edit: I revisited BIOS settings on the other 3970x systems and came up with the following breakdown.
TrueNAS12-U8 is still running the above settings; but I believe the below to be slightly more stable due to further CPU restrictions.
Advanced > OC Tweaker > Voltage Mode > [Stable Mode]
Advanced > OC Tweaker > SRC Spread Spectrum > [Disabled]
Advanced > OC Tweaker > DRAM freq. > [3200]
Advanced > OC Tweaker > Infinity Fabric > [1600]
Advanced > CPU Configuration > SVM Mode > [Enabled]
Advanced > Chipset Configuration > Primary Graphics Adapter > [Onboard VGA]
Advanced > Chipset Configuration > Restore AC Power Loss > [Last State]
Advanced > PCI Subsystem Settings > SR-IOV > [Enabled]
Advanced > AMD Mem Configuration Settings > Socket [0/1] > DRAM ECC = enabled
Advanced > AMD CBS > NBIO Common Options > IOMMU > [Enabled]
Extended Frequency Range (XFR)
Advanced > AMD CBS > NBIO Common Options > XFR Enhancement > Accepted > Precision Boost Overdrive > [Disabled]
Advanced > AMD CBS > NBIO Common Options > XFR Enhancement > Accepted > Precision Boost Overdrive Scalar > [Disabled]
Advanced > AMD CBS > NBIO Common Options > XFR Enhancement > FCLK Frequency > [1600]
Advanced > AMD CBS > NBIO Common Options > XFR Enhancement > UCLK DIV1 MODE > [UCLK==MEMCLK]
Advanced > Amd Overclocking > UCLK DIV1 MODE > [UCLK==MEMCLK]
Boot > AMD-RAID (Or UEFI SW Raid)
