11.3 Beta1 - iocage directory moved
xodlike
Upgraded 11.2-U6 to give 11.3 Beta. Jail directory appears to have moved, and appended /mnt to the existing path, shown below. Is there anyway to move the directory, or set iocage to use that one for its jail root in order to allow jails to work as a workaround?
Thanks.
OS Version:
FreeNAS-11.3-BETA1
(Build Date: Nov 4, 2019 15:18)
Processor:
Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz (8 cores)
Memory:
32 GiB
root@freenas:/mnt # cd volJail1/
root@freenas:/mnt/volJail1 # ls
.plugins
defaults.json
Docker
download
home
images
jails
log
releases
templates
Users
root@freenas:/mnt/volJail1 # pwd
/mnt/volJail1
root@freenas:/mnt/volJail1 # cd /mnt/mnt/volJail1/
root@freenas:/mnt/mnt/volJail1 # ls
iocage
xodlike
root@freenas:/mnt/mnt/volJail1 # iocage list
freebsd-version could not be found at /mnt/mnt/volJail1/iocage/jails/jailB/root/bin/freebsd-version
freebsd-version could not be found at /mnt/mnt/volJail1/iocage/jails/jailA/root/bin/freebsd-version
| JID | NAME | STATE | RELEASE | IP4 |
| - | jailB | CORRUPT | N/A | N/A |
| - | jailA | CORRUPT | N/A | N/A |
indivision
I think I'm running into a symptom of this as well. It keeps telling me that a device is busy inside a "/mnt/mnt/..." path.
Currently trying to remove it to no avail...
drinking12many
I had the 11.3RC1 upgrade fail. The web gui would never start. So I backed up some stuff for a safety step from 11.2 and then did a clean install. I kinda had to do the same thing here I had to destroy the Volume/jails dataset and the Volume/iocage dataset after a failed upgrade to 11.3 RC1 before I could import the Volume without error. Now on to build all my trashed jails :(
